Question about Whirlpool Washing Machines
I have a front loader washing machine. WFE1075BD and the clean pump light keeps coming on. I can't find my manual. Could someone please tell me how to clean it and what to do. Thankyou
    Problem Solver:
  • 3 Answers
There is a drain catch at the bottom of your washer. Remove the kick panel at the bottom of the front of the washer. There is a 2" diameter plastic drain cap that you can screw off and then clean the drain catch behind it.
Posted on Jun 10, 2011
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Smelly water & not going into spin
Try cleaning out the pump access port. It is at the front of the machine.
All sorts of stuff gets into these pumps on front loaders. A partial clog will go what you describe.
If you use a mesh laundry bag it will keep this from happening
Mar 23, 2014 | Bosch Washing Machines
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Our front loader washer is stuck in "drain mode". It sounds like it is trying to drain and some water comes out. The door and all controls are locked. Already tried the usual fix.
water left in machine tub? if so the pressure sw is probably telling the board keep draining. in this case open front cover and drain pump through cleanout access and clean tray-possible clog.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump light keeps coming on
That is the way to fix the issue. remove the debris and hope nothing else gets caught in the trap
Jan 19, 2009 | Whirlpool AWM8163 Front Load Washer
Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Jan 03, 2009 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Our simpson 100 enviro won't drain. We think we need to clean the filter, but we can't remove the filter from the machine. How can we do this?
front loader filters are at the bottom use a screwdriver to remove it may be stuck full of coins.also make sure you dont have a button pressed in by mistake.hope this helps you
Mar 09, 2008 | Washing Machines
Washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
Nov 20, 2007 | Washing Machines
Washing Machines Logo
240 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
