Question about Konica Office Equipment & Supplies
Konica minolta 2550dn, eveytime I clean the inside for loose toners, it won't see the ink cartridges. First Cyan, then the rest one by one. Sometimes it will take the whole day switching on and off until it will work. Is there a quick fix for this?
  • MisterP1 Jun 16, 2008
    It always display the word Cyan is missing even after replacing the cartridge.
    It might help me I really do not know yet until I the delivery of the original cartridge comes. Had it UPS ground.
    However I am postive about it the advice.
    Thanks
    Genius:
  • 1,036 Answers
If after cleaning, the problem persists, Order new print cartridges.
Sometimes they are chipped to "expire" after a set date, then cannot be refilled. It may be possible to fool the system, but Manufacturers will state "replace with new"
I hope this cures the problem for you.
Posted on Jun 16, 2008
  • Konica Master
  • 1,879 Answers
"It always display the word Cyan is missing even after replacing the cartridge."
Sound like service. Hope it's still in warranty.
FixYa
    Brigadier General:
  • 6,966 Answers
Possibly the electrical contacts of the toners (both on the printer side and the toner side) are either dirty or corroded. This would require that said electrical contacts be likewise cleaned and if there are signs of corrosion, scraped. Often these contacts would be at the ends/sides of the toners and would appear as rectangular metal plates roughly 5mm X 10mm. The mating contacts on the printer side would be bended metal pins to match the location and position of those on the toner. In some instances, it may help if you bend the printer contacts in a way that they will exert a bit more pressure towards those of the toner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,142 Answers
When you insert the cartridges please check the metal contacts for which might be causing the problem you need to clean the contacts in the printer itself by powering off (IMPORTANT) that should take care of the issue.
  • 796 Answers
Are you using the original cartridges or the compatible ones
you are arrive in this situation if you are using duplicate ones
    Master:
  • 555 Answers
A manual for your printer, with troubleshooting guide, can be found here.
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
My yellow imaging unit is on back order, is there anyway to still use the printer until it gets here
Basically -no. If you could get a reset chip for it, you could probably carry on using the original drum for some time. For example http://www.tonerstop.com.au/konica-minolta-bizhub-c353-bundled-set-of-4-compatible-drum-chips
May 05, 2015 | Konica Minolta Konica Bizhub C353 Drum...
Magicolor 3730DN toner not installed
I had something similar happen with a Magenta cartridge. My only option was to call Minolta. After hours on the phone they finally agreed to replace the faulty cartridge.
I suspect that from time to tame we receive a cartridge with a faulty chip.
Aug 21, 2012 | Konica Minolta magicolor 3730DN Color...
Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
I think its a problem with the cyan (blue) toner...when i print a colour document the printer works but makes a very stranhge (high-ish pitch) noise and the colour which should come out green comes out a...
The Cyan toner cartridge is jammed, it needs to be taken out and try and move the white plastic gear round a bit to free it. It normally is very stiff and wont move much, but if you can move it a fraction that will do. One thing, did you overfill the cartridge with toner? sometimes that will cause them to seize up.
Delboy
Jan 25, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
48 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
