Question about Jenn-Air JGS8750ADS Gas Kitchen Range
Jenn-Air JGS8750ADS, The starters keep clicking after the burner/s are lit. The outlet polarity is correct, I have also cleaned the burner head with a brass brush and all the holes are unclogged. Additionally, I have lightly brushed the aluminum burner base and the ignitor. The only time it hasn't clicked is after I had the oven in use. This makes it seem like there is a thermal sensor somewhere? There is no other info/ suggestions that I can find to fix this model. Someone help, please.
aborcass
  • 2651 Answers
SOURCE: jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Posted on Mar 15, 2008
Cory5468
  • 125 Answers
SOURCE: spark ignitor won't stop clicking
Dry the ignitors and see if that works. If not, then get new ignitors.
Posted on Apr 14, 2008
SOURCE: Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Posted on Dec 22, 2008
  • 14 Answers
SOURCE: Jenn-Air JDR8895 dual fuel--ignitors won't work after flood
hi your ignitors wont last long, they are similar to a fuse, you should be able to change the ignitor and if it still does not ignite look to see the space of the ignitor and try shorten it.
Posted on Feb 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: jenn air oven doesn't work model jgs8750ads past
Yes. F1 error is a bad control board.
These boards are very sensitive to power surges,lightning and power brownouts.
Posted on Nov 20, 2009
Testimonial: "Thanks for the tip about surges I can work on that in aditon tot he repair "
JGS8750ADS, When you light the burner/s, the electronic starter doesn't stop after the burner is going...it just keeps on "ticking" away
The igniter is designed to spark at all the burners, no matter which valve is turned on. Once it is lit, turn the gas valve to low med or high settings. If it still sparks after you have turned the valve, it may have gotten wet. Did you recently clean it? Let it dry out for a few hours. Or is this a new unit? Is it still under warranty? Call the manufacturer for free warranty repair.
May 15, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
My jenn air espressions gas cooktop has four burners. When
Remove the round burner plates and clean thoroughly in soap and water. Clean the burner ring where the burner plates rest with soap and water.
Let me know what you find.
Dec 13, 2009 | Cooktops
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Sep 22, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Keeps clicking after lit
your ignition button is sticking down after you press it to light the burners, give it a few taps and clean underneath the button.
Aug 23, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Ignition keeps clicking
the spark modual is bad and needs to be replaced
Nov 25, 2007 | Thermador 37 in. CEF365CS Electric Cooktop
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Jenn-Air JGS8750ADS Gas Kitchen Range Logo
56 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
