Question about Thule Honda CRV Specialty Rack
My 2003 Honda CRV sounded like it had a weak battery. The original battery went bad last May. Now (the following October) it sounded like it was going bad. It would turn over slowly 2-3 times and then click, sounding like a bad battery. After 2-3 tryâ??s starting it, it turns over as usual and starts. This happens about 1 out of every 20 starts. The engine temperature or outside temperature doesnâ??t seem to be a factor. I returned the battery and they gave me a new one but the problem continued.
My crv is straining to start
Bad starter or weak battery, loose or corroded battery terminals.
Dec 05, 2013 | Honda Cars & Trucks
My Honda CRV 2002 holds down and do not advance,What shoudl that be? and what should I do?
explain.
but sounds motor weak or tranny slippage
post full symptoms, hot and cold engine. and all modes.
speed, hills , all modes what it does good and bad.
Sep 29, 2013 | Honda CR-V Cars & Trucks
Instrument panel on 2003 Honda CRV starts flashing when headlights are on
Have had a similar experience with my 2000 Ford Windstar. The extra load added by turning on the headlights affects the instrumentation power feed. The illumination flickers and the gages go crazy. Your 2003 CRV may have its original battery which is near death. It took me four batteries to stabilize things and I still get the flickers at night sometimes
Apr 13, 2013 | 2003 Honda CR-V
Leave honda crv 2003 in parking lot while on vacation (7 days) come back car won't start I mean nothing, need to jump start and it's okay, Happened twice I left with everything off and shut with...
not really, except unhook the battery. there are several things constantly running all the time. 'clock,computer, etc. eventially, the battery will drain. then again, your battery may be weak. an auto parts store will test it for free.
Sep 15, 2011 | 2003 Honda CR-V
Battery got disconnected and i lost the pin number to set up the cd player and clock..what should i do. car is honda crv 2003 ......please help..thanks!
battery got disconnected and i lost the pin number to set up the cd player and clock..what should i do. car is honda crv 2003 ......please help..thanks!
May 02, 2010 | 2003 Honda CR-V
Needs my crv honda sound stereo code
You will need to take the car to a deal and verify you are the rightful owner of the radio as this is the purpose of the code.
Best of it. While at the dealer why not ask about any recalls on your car?
Mar 17, 2010 | 2003 Honda CR-V
On my 2003 Honda CRV Sport, When I lock me steering I get a grinding noise, does anyone what this is? Cheers Alan
if the noise only occurs at full lock then it is the pump clutch slipping which is normal.sounds awful but okay.
Mar 12, 2010 | 2003 Honda CR-V
My 2003 honda crv seems to be making a lot of growling noise especailly when i am pressing my gas padel and my a/c all of a sudden stop working
I would have the serpentine belt and all the pulleys looked at. The clutch on the ac pump may have went bad and now you hear a grinding.
Oct 29, 2009 | 2003 Honda CR 125 R
Relay clicks wnen i hit the starter
Sounds like a low battery but if has 12.6 volts then I would bench test the starter.
Apr 26, 2009 | 2003 Honda CB 750 Nighthawk
Replace Timing Chain for 2003 Honda CRV?
Rule of thumb this is a timeing belt and it should be changed every 75,000 mile as a general practice. I hope this helps, dont forget to rate my answer, thanks
Feb 20, 2009 | 2003 Honda CR-V
Thule Honda CRV Specialty Rack Logo
77 people viewed this question
Top Thule Winter Sports Experts
ray gallant
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
