Question about Hitachi 32UX59B 32" TV
Can you please let me see a picture of vertical ic.im just a new technician but very interested in trouble shooting.
3 Suggested Answers
rey jr
  • 149 Answers
SOURCE: sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Posted on Feb 25, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Circle Vertical IC please on picture
I've cropped out most of the picture so it would fit here. The vertical output IC is I601. It's circled in the picture below:
If you can't place it from this part of your image, it's on the heatsink just above and to the left of the horizontal output transformer, which has the high-voltage lead running to the picture tube. Resolder the IC connections and that will probably take care of your trouble.
Posted on Mar 08, 2010
I have a sanyo tv when I turned it on it only had a thin blue line across what can I do to fix this
hi this kind of problem it needs a proper trouble shooting then can be hand held by a trained tv technician. usually the cause is malfunction in vertical section in the main board. it would be a bad vertical ic, defective capacitor or an open resistance going to the ic. this can be check through component checking using a digital tester. if you don't have any idea what to do just send to the qualified tv technician .
Nov 11, 2012 | Sanyo Televison & Video
I have a toshiba Theaterview SD television. The sound is fine but the picture is a a thin horizontal line? What can I do to fix the problem?
The problem of your tv is the vertical deflection. Try to tap the side of your tv and observe if it will go to normal size if react the problem is the vertical IC there is a loosed or cold solder in the pin. If you are familiar with the electronic parts you can fix this by resoldering the loosed or cold solder to the vertical section of your tv. But if you tap the side and does not react you should replace the vertical IC, or you can contact a service technician to do it for you good day and best regards. Note before doing some trouble shooting you should unplug the unit.
Aug 22, 2011 | Toshiba 32A43 32" TV
HI When I start my ALBA TV, there are horizontal lines across the screen with high noisy sound. I bought this TV just few months ago. thank you
The horizontal line in the screen is the problem cause by vertical output driver.The vertical output is located at the verical section.Maybe theres a loose connection in vertical section or leaked capacitor.It also the cause of deffective vertical ic.So its better to repair and trouble shoot by the authorized technician.If you have knowledge in Tv.Try to replace the leaked capacitor.
Jul 17, 2011 | Televison & Video
T.V. picture won't come on ( or sound) only vertical stripes.
first thing you need to do open the back cover to trouble shoot, check burnt parts at vertical section and then turn on the TV check voltage going to vertical IC if present.if voltage is present unplug again then check leak capacitor near the vertical IC also open resistor.
Apr 18, 2011 | Zenith Televison & Video
Mar 08, 2010 | Hitachi 32UX59B 32" TV
How do adjust verticle picture on Hitachi 46F510
You can adjust vertical height through the service menu, but i would recomed that you trouble shoot the vertical section as its probably a solder joint , leaky diode or something that is causing the problem. Often its bad solder at the vertical output IC itself that causes that sympton.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Picture distortion
refplace the regulator ic or transistor. chick zener diode. chick vertical capacitors
Sep 09, 2007 | Panasonic CT-36SX31 36" TV
No picture
If you know how to trouble shoot solid state electronics, you should not have a problem trouble shooting this set. it sounds like a bad solder connection But these sets are not made for a consumer to repair as they are all soldered into placxe and inside a TV set is not tyhe place for a peep to br if he doesent uinderstand thongs
Sep 09, 2006 | Hitachi 32UX01S TV
Help problem with picture
This sounds like theres a capacitor somewhere in the vertical sweep circuit. You can replace the capacitor if you have a soldering iron and some electronic experience on trouble shooting tv sets. It is most likely from what you described the capacitor off the high voltage transformer that supplys the b+ to the vertical output IC. A repair person should be able to give ya a ball park on the cost as Im thinking somewhere from 85 to 135 Bucks depending on if theres only one cap goiung bad or could be a couple or more starting to dry up. So its your ball now .. Do you wanna spend that much to repair the set Do you like the set? is the set over 3 to 5 years old? Its up to you. Good Luck
Jun 03, 2006 | Orion STV2763 27" TV
SONY KV-27v36
this problem would be in your power spply or the sweep derived power supply. probably a bad capacitor or regulator IC/transistor. Unless you know how to trouble shoot electronics them please have this set looked at by a pro. Good Luck
May 25, 2006 | Sony KV-27V36 27" TV
Hitachi 32UX59B 32" TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
