Question about Reliable T730A Canister Steam Vacuum
My Reliable T730A Canister Steam Vacuum is not working. The red (empty) light stays on even though its full and it doesn't produce any steam. I doubt that the water is getting down into the heating chamber. How easy is it to take apart and clean or can I just blow compressed air through it? Any help most appreciated. Steve swilk28@satx.rr.com
  • 2,299 Answers
You can probably just blow it out with the air compressor. If you have a air pressure regulator on the air compressor then I would turn it down to about 30-40 psi. Then try to blow out the line.
Posted on Nov 09, 2010
No steam 2400
Water level low or clogged steam jet
Jul 07, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
Steamer
Try running a phial of Kalstop through the boiler to descale the boiler unit. Calicification in the boiler and on the controlling solenoid can cause the unit not to produce steam. My boiler unit was so corroded that I had to get the boiler container completly replaced.
Feb 02, 2014 | Polti AS700 Canister Steam Vacuum
Heats up ok but no steam when temperature reached
Water indicator light keeps flashing and bleeping even when iron is full ,this is a brand new iron.
Sep 26, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
After a short time of using my steam cleaner the red light comes and steam stops.
red light of course means stop, so do. second its a vacuum so my next assumption is its full either it needs to be emptied or cleaned so it can resume its job. I hope this helps.
Jul 13, 2011 | Domena NVT200 Steam Vacuum
It is getting up to tempeture but it will not produce any steam
Your machine need to reach boiling point to produce stem? Then check if all the sustem is sealed other than the pip outlet gun and it should now operate with the gun trigger ( pull to operate, but only when the water within the vessel is boiling, producing steam)Hope this helps Regards Mike
Jul 08, 2011 | Polti Vaporetto 2400 Canister Steam Vacuum
Unit gets hot but doesn't produce steam!
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
l
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Reliable T730A Canister Steam Vacuum Logo
89 people viewed this question
Top Reliable Vacuums Experts
JoeVacs
Are you a Reliable Vacuum Expert? Answer questions, earn points and help others
