Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
Change of hard disk from 160 gb ide to 250 gb sata
I have got asus VIA K8M890 motherboard.will the 250 gb sata will run on it with processor AMD 64 ATHLON
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Posted on Jun 16, 2008
Windows xp does not install
If your hard disk is a SATA disk then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 23, 2013 | AMD Phenom II X2 Processor 560 (3.3 GHz)...
Can I install a none sata ide hard drive in a Asus Cm1630-06
lilpolak
Most motherboards have one IDE port on this that you can run 2 IDE devices off of. Note the main reason for this IDE port is not all ROM drives are SATA yet but you can run hard drives off this port as well.
Let me know if you have any more questions or problems
Issken
http://www.fixya.com/users/issken
Sep 29, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
I'm wondering if my ASUS K8V-X motherboard will support a 320 GB SATA hard drive.
Check is there ports available for connect SATA HDD. If yes it will support .
Thanks.
Oct 14, 2009 | ASUS K8V-X Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Where can i find sata driver for XP?
there are 2 way to solve this problem,
1. change ACHI mode to IDE in BIOS setting
2. Make a XP installation CD with SATA RAID dirver yourself.
googd luck!
Jan 30, 2009 | Computers & Internet
Regarding External Hard drive
Could you tell us the exact error message?
Aug 28, 2007 | AMD Athlon 64 X2 3800+ Dual Core Processor...
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
