Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
On my Poulan PP4218AVX the chain keeps coming loose and falling off. I have retightended it but it keeps coming loose after about 1 minute of operation. what is going on? and how do i fix it?
  • 7,733 Answers
2 options:
Change for a new chain - the chain is too stretching
Put a pressure ring on the adjusting screw - to help tighten the chain
Posted on Nov 09, 2010
Can I get a replacement clutch cover for Poulan Pro model PP4218AVX
Yes, Just use the one from the PP4218AV PN 545012003. I just can not tell if the adjuster assembly comes with the cover or is need to ordered separately.
Jan 24, 2015 | Poulan Pro Pp4218av 18" Gas Chain Saw...
The chain/bar won't stay tight. Becomes loose after several minutes of use.
If the nuts holding your guide bar are not worn, then you must replace the tensioner adjustment
Jul 29, 2014 | Poulan Garden
Compression test on poulan pro chain saw
Yes, but 100 or lower and you need to think about ring and/or cylinder, piston and ring set.
Jul 27, 2014 | Poulan Pro PP4218AVX 18-Inch 42cc 2-Cycle...
Is there a replacement clutch cover for the Poulan PP4218AVX?
Hello Dave;
If a Poulan PP4218 your answer follows; if not post back with the correct model number and we can replace that too.
Poulan “PP4218AVX” IPL (exploded parts list)
We are going to replace this page 1; item 47
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2010/NIUS2010_545103408.pdf
Poulan “PP4218AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 44; Clutch Cover Assembly; $9.50.
You also need;
• Item 43; Bar Mounting Nut; $0.56 each (need 2) and
• “Engine Assembly” print; Item 44; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
You will need retain the original model number IPL, there may be internal differences.
Down loadable PP218AVHD IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2006/NIUS2006_545014325.pdf
Poulan “PP4218AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047503.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Yes i cracked the oil housing for my poulan pp4218avx 42cc chain saw and I was wondering if they sale a replacement housing to repair the saw.
A Poulan PP4218AVX Gas Saw link follows:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
See the "Handle, Chassis and Bar Assembly" print, item 38. Is this what is broken? If yes it is possible to replace it, it is not terribly expensive, it is a great deal of precision work. I hope you already removed the clutch (left handed thread). I would probably keep this for parts and purchase a PP4218AVHD Gas Saw Type 2 as a replacement. HTH
Lou
Feb 23, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a new primer bulb Poulan WildThing 42cc CS
Item 18 on the "Engine Assembly" detail IPL here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If this is not your saw you can fin d your here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
HTH
Lou
Jan 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The back post that holds the bar has come loose and turns
Provided your saw is a PP4218AVX, tThe bar studs are item 41 on the "Handle, Chassis & Bar Assembly" here:
If not an AVX the correct IPL can be found here:
Poulan.com
The tank is usually split to install a new bolt. Please read some of the repairs here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Sealing the new bolt to the fuel tank is the hard part.
Good Luck
Lou
Jan 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an 18 inch bar and the chain has to be tightened every few minutes. I tighten the nuts against the bar as tight as I can but the bar must still be moving to loosing the chain. Do I need to add lock...
There is an adjusting pawl with a screw that does the tightening. The nuts only clamp the bar once the chain is tightened. The adjusting screw is in the plane of the bar. The pawl may have disengaged the bar or may have broken.
Jan 01, 2010 | Poulan PP4218AV 18" Chain Saw
Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
953 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
