Question about Ovens
The oven will not heat. I used it on sunday and notice it took a long time to bake. When I went to use it monday night it would not heat at all. Can you tell me how old the range is? We moved in in september and it was already here. We also have always noticed a gas smell.
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 09, 2010
Kems308sss05 starts heating to a preset temp, then stalls. Both broil/bake elements get hot, no spots or breaks. When I try to preheat again, the start temp is less than the # it stalled at.
Top 42 Complaints and Reviews about KitchenAid Wall Ovens
www.consumeraffairs.com > Homeowners > Ranges/Ovens/Stoves
Rating: 1.6 - ‎35 votes I missed 2-days of work, once for diagnosis and then another for them to ...KEMS308SSS05 - I purchased this product in Jan 2012. ... Ordered parts, two weeks later parts came and when the heating element was .... I used the self-cleaning unit in top and bottom and noticed in November the temperature took a long time to ...
Nov 08, 2015 | Ovens
My built in whirlpool oven has no power
What is the model number of the unit?
Nov 05, 2012 | Ovens
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Oven doesn't heat up
WHAT KIND OF OVEN? NEED MORE INFORMATION
Sep 10, 2007 | Tecnik TKC195/3 Electric Single Oven
Oven heating problems
I'm afraid you might need a new thermostat. The only other thing you might check is to make sure that your 'vent' is not blocked with a pan or tea kettle etc., but I'm pretty sure it is a thermostat.
Jun 09, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
