Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Powder detergent does not dispense into the dishwasher during wash cycle. The powder gets wet and stay in the dispenser and then when the drying cycle comes on it dries the powder and it becomes hard in the dispenser. The dishes are not getting clean
  • Whirlpool Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Nov 09, 2010
Gritty murky crockery powder dispenser has sticky powder after the wash still in it.
Is it the dispenser that has murky powder or the dishwasher?
Dispenser: Is the dispenser being blocked from opening all the way during the wash load? This can happen in some dishwashers if a tall pan or dish is blocking the dispenser from fully opening. Hence, part of the detergent stays inside the dispenser and is goopy/murky/yuckie.
White powder on racks, nonstick spatulas, silverware basket: There has been a recent change in dishwasher formulation that can cause a white residue to deposit. Phosphates have been all but removed from dishwasher detergent. If there is a white residue on the dishwasher racks, etc, try a dishwasher cleaner such as Affresh for dishwashers and then look to consumer union for a new formulation. Be of good cheer: phosphates are very bad for our waterways, fish and fauna. This change was made in laundry detergent about 16 yrs ago.
Oct 11, 2011 | Dishwashers
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
Powder detergent not distributing in ge quiet power 3 dishwasher
Try storing your powder in the dryer cupboard or in a warm area
It is more than likely that it is damp when it is going into the machine which means it clumps up instead of mixing with the inflow of water
Other thing to check is is there is a restriction at the back of the dispenser drawer which is not allowing the powder to flush down into the machine.
Finally , dry the dispenser slots with kitchen roll and give them a spray with a good quality furniture polish, allow it to dry for a few minutes and then buff it with a cloth, the silicone or wax in the polish should help the powder to slide
Jun 02, 2009 | General Electric Adora GHDA670N Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Simpson brand dishwasher won't disperse detergent tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
Feb 18, 2009 | Dishwashers
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
604 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
