Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
F10 error code on Frigidaire Model# FEF368GCA Electric Range- Why? Repeatedly beeps. How do I fix it?
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 506 Answers
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
Posted on Dec 15, 2009
SOURCE: what is error code F10
Tiger.......I have a Kenmore Model 790 as well, and am getting the F10 Error code. It says in the manual that it is either the RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control), but I am trying to find troubleshooting tips myself, as I do not want to pay $130 for a tech to come to my house. I know you can press the oven (off) button to stop the beeping momentarily, but the manual also says that the oven may need to be reprogrammed.....which is what I'm trying to find how to do. Sorry I couldn't give you a quick fix solution, but I'm am still searching.
Posted on Aug 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire Classic Range, Model # FEF366CCB, F1 error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^%$RF
Posted on Oct 01, 2010
taran_2005
  • 10515 Answers
SOURCE: Electric Range Frigidaire Professional Series
The last expert is correct.
According to the Frigidaire technical documentation, most likely the cause of the problem is a bad Electronic Oven Control (EOC).
Check the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC
You could try to disconnect the power supply for few minutes, say 15 minutes and see, if that could help the situation unless you need to replace EOC/Clock/Control board.
I don't think it is sensor as this is a common problem on these units and 99% it is faulty EOC.
Let me know,if needed further assistance.
Note - Kindly perform the repair, if you have prior appliance repair experience. These ovens are quite dangerous to work. It could not only damage the oven but could also harm you,if done in an appropriate way.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2010
Code f10 and f29 came up while On self cleaning what does this mean ?
Washer Error Codes Below is a list of... - Elite Appliance ...
https://www.facebook.com/permalink.php?story_fbid...id...
Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, ... Check pump trap and clean. ... Musical series of beeps every 5 seconds and Wash cycle light flashing-Washer is overloaded. ... E47--Board thinks the door PTC circuit is open in spin .... F29--Door unlock error
Range Error Code F10: Troubleshooting Runaway Oven ...
? 2:20
https://www.youtube.com/watch?v=z6tcnpDKDns
Oct 1, 2015 - Uploaded by searspartsdirect
If you see F10 on your range, it means that your electroni. ... exceeds the temperature you set it at in either .
Nov 07, 2015 | Electrolux E30EW85EPS Electric Kitchen...
Frigidaire electric range #GLEFZ384GCA has an F10 signal, and appears to continue heating when set at 170.
Thank you for allowing me to assist you, Friend.
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Sep 14, 2014 | Frigidaire Gallery GLEFZ384GC Kitchen...
F10 fault
F1 through F10 fault codes are runaway temperature codes.
If this error code is shown while the oven is in day time mode, the Electronic Oven Control (EOC) would need to be replaced. Otherwise it may be the oven temperature sensor or Resistance Temperature Detector (RTD sensor).
Sounds like you will need to contact an appliance repair technician in your area to test each to isolate the problem.
Apr 13, 2014 | Frigidaire PLEF398AC Electric Kitchen...
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidare range and it is flashing F10 and Beeping repeatedly
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Here is the probe to order.
Here is the EOC to order.
Jan 07, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore model 970(frigidaire) electric range displays F10 fault when i use the oven shutting down the oven and beeping. Help me please
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Ovens
F10
Hello,the F10 error code means "Runaway temperature"most likely the problem is bad Electronic oven Control ("clock/timer").it has to be replaced together with the overlay because it's glued to the clock.
Thanks
Jun 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
287 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
