Question about Mitsubishi WT-42315 42" TV
Lightning strike killed my wt-42315 mitsubishi
I press the power button and absolutely nothing happens. No click, no hum, just nothing. Could it be a fuse? Could it be the Power supply? I'm lost and I would like some advice before I call a technician to fix it.
  • TvDave9999 Jun 16, 2008
    Thank you eagle338! I'll take a look inside my set. I will not touch a thing though! I just want to get an idea of what's wrong before I take it in.
    Again, Thank You.
    Dave
  • 4,889 Answers
Yes it can be either a Fuse or the power board itself. First lets talk about the fuse. What we are looking for is a burnt ceramic fuse
that will look like this http://www.radioshack.com/sm-ceramic-and-thermal-fuses--fi-2032300_cp-2032058.2032234.html
Check the rating( something like 5v, 2A or something like that) and get replacements with the same values. Should cost you around 10$ for 6 of them. If this doesn't help then its gotta be the powerboard and if this is the case then the powerboard is not user servicable. You will have to get it replaced! Good luck!
Regards,
Sai.
Posted on Jun 16, 2008
  • eagle338
    eagle338 Jun 16, 2008
    Yep surething! Let me know if you found something..
What's the likelihood of my TV being able to be fixed after a lightning strike killed all electronics on one wall?
Probable power supply fault now. Maybe if you replaced the power board it might work again.
Jun 19, 2017 | Vizio Televison & Video
Wy won't my mitsubishi tv turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
Jul 22, 2014 | Mitsubishi WT-42315 42" TV
Red color shifting and ghosting on my wt-42315
Tv have a problems known as a convergence picture problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board have dead parts like 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must have be replaced to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jul 07, 2011 | Mitsubishi WT-42315 42" TV
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
Mitsubishi WT-42315 42" TV has a red/Green color seperation
you need to replace the convergence chips, i had this done about a year ago and costs 450.00 usd
good luck
Jan 10, 2009 | Mitsubishi WT-42315 42" TV
Convergence board
YOU WILL NEED PROFESSIONAL HELP THIS IS NOT A DO-IT-YOURSELF JOB. SORRY
Jun 01, 2008 | Mitsubishi WT-42315 42" TV
No power on
It could be coolant leaked from the CRTs, or a failed fuse due to the conv ICs shorting out or going open, depriving the turnon circuitry of its proper voltages.
These are the usuals. Since Mit has very elaborate protection circuits, it could be anything. More troubleshooting needs to happen before we'll know more.
I do a phone coaching service if you want to check that out.
Mr Bob
Apr 29, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313
DM module needs repair = replace bad capacitors ( bulged tops) with four 1000mf / 25v ........T.
Dec 03, 2007 | Mitsubishi WT-42315 42" TV
Mitsubishi WT-42315 42" TV Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
