Question about Roper RAS6233KQ Top Load Washer
Lidswitch how do you replace?
  • 413 Answers
To access the lid switch, REMOVE POWER, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white or gray in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
Posted on Jun 16, 2008
I have a Whirlpool LSR6232JQ1. I have to replace the lid switch. How do I do that?
What you do is flip up the controls,themobilian_287.jpg unplug the lid switch connectionthemobilian_288.jpg remove the cabinet themobilian_289.jpgand then you can replace the lidswitch. Here is a nice video which shows you how:
I have a complete more and a manual here
Nov 27, 2010 | Whirlpool Washing Machines
Tip
Direct drive lidswitch replacement
All of my tips have been tampered with. I deeply regret I must remove the content from these tips. I will not write another tip for fear of further tampering of my literature. If you have any questions I am on facebook.
JW Webster
on Dec 16, 2009 | Washing Machines
I have a kenmore elite and I replaced coupling and still does not spin
a common problem with whirlpool/kenmore top loaders is the lidswitch. The washer will fill and agitate, but will not go into spin if it thinks the lid is open. This is a safety feature. The only thing you can do is replace the lidswitch.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
After the washer machine fills with water it does not drain or spin, the clocking mechinism /switch does not match the cycle.
Look for signs of a broken lidswitch.
Flip up the controls unplug the lidswitch and check it for continuity or jump it out to see if the washer will start working. As far as the dial indicator being broken To replace that you yank out the retaining rod in the rear to release the knob then you can replace the skirt easily2cc26e6.jpg
Their are four videos and a tech service manual here: How it works Direct drive washer
Oct 19, 2010 | Kenmore Washing Machines
Blowing fuses on the lidswitch asembly so I replaced
the one screw that holds the asembly lousen it and slide it back and forth also make sure the lid switch acturater is in place properley u should be able to hear it click as u raise and lower the lid.hope this helps dont lousen that screw to much haundi24
Oct 26, 2009 | Maytag 22 Cycles Topload washer, SAV365Z
Kenmore Washing stops at spin cycle.
It sounds like your lidswitch. If it spins after you open and shut the lid, you must be jarring the lidswitch. This is a safety so kids can't open the machine while it is spinning fast. Just replace the lidswitch.
Jan 19, 2009 | Admiral AW22 Top Load Washer
I replaced the lidswitch on a Kenmore 80 series washer. Nothing
Possible bad pressure switch. Turn unit on and jump out 2 wires at a time (3 wires go to it). See if any of your combinations get unit running (one of them will cause water valve to open); if so then that is your problem. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washer wont empty and spin
BAD LIDSWITCH OR THE SCREWS ON THE LEFT SIDE HINGE ARE LOOSE CAUSING THE LID TO BOW UP APPLY PRESSURE ON THE LID TO GET IT TO START SPINNING IF IT DOES TIGHTEN THE SCREWS ON THE HINGE IF IT DOESN'T THE LIDSWITCH NEEDS TO BE REPLACED
May 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Could the lidswitch be causing the problem as well
yes could be the lid switch depending on the model they are held on by two screws ive seen one break and let the switch hang at an angle so that the lid strike cant fully depress it
May 19, 2008 | Kenmore 23812 Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
51 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
