Question about GE Dishwashers
I have a pot scrubber 640 GE permatuf dishwasher. The door spring either broke or became detached. Need diagram
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
chazman05
  • 48 Answers
SOURCE: Dishwasher leaving residue inside unit after wash is complete.
THere is a no filter on this unit just a strainer which is visible when opening the door.(its located near back on the bottom) You can take it off and check for pieces of trash or things that have made it by. The best idea is to take a few cups of vinegar (white) and put it in the soap dispensing door. Also take a big Glass and leave it upright and fill it with vinegar. Then run a normal load but dont use any other soap. ALso if your unit has a spot use Jet Dry or simliar products they really do help.
Goodluck
Posted on Dec 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: my dishwasher leaks from underneath directly in
Seals are gone.
Replacement is the only answer.
Repair is not recommended.
Posted on Feb 22, 2009
jsrock516
  • 5911 Answers
SOURCE: spring on door is broke. do I need to pull
The door springs are located at each door hinge and connect to the frame body along each side of the dishwasher. If you remove the lower toe panel directly below the door you should be able to see them. However, in order to access them to repair/replace you WILL need to pull the dishwasher out to get to them in most cases. You may not have to remove the dishwasher all they way, however, if you have enough slack in the water supply line, power cord and drain line. Just follow these steps:
1. Turn off the main power or unplug dishwasher.
2. Remove lower toe panel.
3. Remove the screws under the counter top holding the dishwasher in place.
4. With the screws removed, carefully pull the dishwasher out. Watch through the toe panel opening to see if you have enough slack in the power cord and water lines.
You may have enough clearance to locate the springs on the each side to make your repairs. If not, you will need to turn off the water supply and disconnect the water supply line on the left hand side inside toe panel. You may also have to remove the electrical lines inside the junction box inside the toe panel. It is usually located right in front for easy access. Make sure the power is turned off at the breaker, or the unit is unlugged before servicing the electrical supply. For reinstallation, the color codes are as follows:
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN (or Bare) - GROUND
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Aug 29, 2009
  • 33 Answers
SOURCE: GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Posted on Sep 12, 2009
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
My GE pot scrubber won't fill with water, all kof
you are probably in need of a new water inlet valve part #WD15X10003, should be around $35.00. this valve opens up at the proper time on the timer to let the water into the machine. hope this helps.
Oct 15, 2009 | GE 24 in. GSD2600GBB Built-in Dishwasher
Sep 12, 2009 | GE Dishwashers
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Goodluck
Dec 11, 2008 | GE Dishwashers
Dishwashers Logo
172 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
