Question about Crosley 1950 Pay Phone
Crosley 1950s Style Payphone
I have a Crosley 1950s style payphone. I have had to exchange it about five times now because of problems getting a dial tone and dialing. Usually it will work for about a month and then the problem starts. I've checked all connections and they are fine. Since this has happened so many times, I cannot be the only one having this same problem. I hav searched the internet for help, contacted the company etc. with no luck. Do you have any suggestions?
How do I find the location of the payphone a txt was sent from
Puzzled, payphones don't send text messages???
Even if they did, the only way you would find that information would be if you were part of a government department and had a warrant. Sometimes the payphone number is displayed, but they don't accept incoming calls.
If a text was sent from a cellphone by someone standing in a phone box, the same applies. Geo-location can only be obtained by warrant.
Dec 02, 2015 | Cell Phones
When I first got this phone I could speed dial I guess I need to reprogram it? How?
I found the manual, so you can look up what you think speed dial is. The manual does not mention that option.
http://www.payphone.com/shop/instructions/VT-CS6219-2.pdf
Apr 19, 2015 | Vtech CS62192 Cordless Phone
I just bought a payphone on ebay, advertised as new, but it does not have any info with it and I do not see anything on the phone showing make or model. Seller says he does not know either. What do I do...
The guts of smartphones were made by 2 companies, Elcotel and Protel. Here's a link to the Payphone.com website. Perhaps you can match a picture of the phone and download a set of instructions. http://www.payphone.com/Pay-Phones/
Carl
Dec 28, 2010 | Lands Phones
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
I recently got this old "Panasonic Easa Phone KX-T2835" from a thrift store and my phone only rings twice before my answering machine picks up. How can I make my phone wait till 4 or 5 rings before it...
Have you tried erasing all the (incoming) messages on the machine? Does that let it ring the full 4-ring-cycle before it picks up?
It's been years since I owned one of these, but there should be a switch (on the side of the unit?) for a feature called "toll saver" If you find this, switch it off.
The idea was from the days of payphones -- if the machine had no messages, it would ring 4 times before it picks up. If there were messages, it would pick up after one ring (or sometimes two)
If you were out on the town and wanted to check your messages, you'd put your dime in a payphone and call home. If it rang three times, you can hang up the payphone and get your dime back, knowing there's no message to check.
Jun 14, 2010 | Panasonic Lands Phones
Phone receiver not working
Is this a replica or a real payphone? Will the transmitter cap unscrew?
A couple of things to try, is take out the transmitter, hold it in the palm of your hand (with the holes in your palm) and slap the assembly on a hard surface. That unpacks the carbon granules.
If that doesn't work, it also may be that a relay is operating because it is want is called a Postpay payphone. Try reversing the Tip and Ring (green and red) line connections and test it again.
Finally, a genuine "g" handset transmitter capsule is about $3, making it cost more to ship than buy. Your picture shows a non "armored" handset cord. If that's really the truth, is the handset black and non-modular? And how does it fit into the payphone housling?
Please don't rate this until you have answers....
Mar 28, 2010 | Crosley 1950 Pay Phone
Fitting a new battery to a bt contour payphone
I have a bt contour 100 that had the same problem no dial tone and nothing on the screen this is easily fixed by soldering in a new battery or soldering in a battery holder / battery back that takes 3 aaa batteries in place of the old battery you may have to solder two separate wires into the positive side and one wire into the neutral side after the old battery has been removed once you have soldered two wires into the positive thoes two wires need to be connected to the positive side of the battery holder and the other single wire into the neutral side of the battery holder once done correctly when you have inserted 3 AAA batteries and reset the payphone it will start working again bare in mind when you reset the payphone the pin number will go back to its default setting you may have to contact bt payphone help desk to get the default pin if you don't already have it there is a company offering to convert the bt contour payphone to run on regular alkaline batteries which are easily replaced but getting it professionally converted would come at a cost you can easily do it yourself giving some basic knowledge of electrical wiring and some common sense. The payphone runs on a 3v dc lithium battery that costs £9.99 on some sites on the Internet I believe that you can also get it to work on a 3v DC adapter but I have not tested or tried running my payphone on a power adapter as converting it to run on aaa batteries is easier and quicker to replace
Nov 03, 2009 | Lands Phones
Ecosse Pegasus Payphone User Guide needed
999/112 is not solved in the tariff settings it would indicate either a flat battery , a coin jam, or lack of time and day programming
Mar 24, 2009 | Lands Phones
We have a payphone that the user can hear the person they are talking to fine, but the person they are talking to cannot hear them. We need parts or repair advice.
The handsets receiver has gone bad. Just have a technician replace the handset Or if you wanna do it yourself. The handset is like $20 and you can get them at PayPhone.com
May 01, 2008 | Lands Phones
Hi, Ive got a BT Contour 100 Payphone, but there is no dial tone or display. Cheers
You need to dismantle phone and replace Varta CR1/2AA 3Volt lithium battery. Dismantling is easy enough but you MUST lay out the screws etc so they go back in the right place, particularly the one with the two nylon washers underneath the head.
Apr 23, 2008 | Lands Phones
Crosley 1950 Pay Phone Logo
52 people viewed this question
Top Crosley Lands Phones Experts
Lisa Demont
Lisa Demont
Level 1 Expert
Are you a Crosley Lands Phone Expert? Answer questions, earn points and help others
