Question about Hayward Navigator Pool Cleaner
My pool vac still runs but is extremely slow, barely moving. What would the most obvious problem be?
  • 25 Answers
Low flow would be the first thing to check. A clog in the hose, a leaf canister or pump basket that's full or a dirty filter.
http://www.cpo2go.com
Posted on Dec 03, 2010
Tiger Shark moves slow
no tension need to replace tracks
Jun 25, 2012 | Aqua Vac Tiger Shark
No pressure for the filter outlet.
it sounds like the filter is clogged somewhere
May 09, 2012 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
I followed your directions to replace the belt on the Eureka Smart Vac 4870 upright bagged vac -- worked perfectly. Except when I turned it over and started using it -- the vacuum was in...
Obviously something is wrong. Take it to a vacumn repair shop and get it done right. The few dollors is not worth the frustration.
Mar 02, 2017 | Vacuums
Polaris vac doesnt reverse . which way is it supposd to be running, watr fow away from vac or towards vac?
When these pool cleaners are not reversing, there are several things that you need to check.
  1. Make sure that the back up valve is cycling (it should move in multiple directions).
  2. Check the wheel RPM and make sure that it is between 28-32.
  3. Make sure that the debris bag is empty.
  4. Check to see if the head float has water in it. If it does, replace it.
  5. Make sure that the feed hose is floating.
May 24, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Pool vac moves slow and to the right only
you may have some bad bearings on the turbine or the "A" frames. You have to take the unit apart from the bottom and inspect the bearings on both the "A" frames and the turbine itself. Make sure the shoes on each pod have a good amount of padding left, like 1/4". If you do have bad bearings, you can purchase a turbine kit with "A" frames that will come with all the parts you need to get it running like new.
Jan 02, 2010 | Hayward Navigator Pool Cleaner
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
My Northstar 1.5 hp is developing less than 10 psi. It occasionally squeals briefly when started. Otherwise it runs smoothly. The pool vac barely moves at all, even with the skimmer turned almost...
Hi George It's your impellar or bearings you need some tools for the bearings but if it is impellar you can do this I would suggest you just take it in and rebuild hole thing as you will be better off in the long run.
THANX FOR USEING FIXYA
RATE ME
Apr 27, 2009 | Hayward 1.5 Hp Northstar High Performance...
Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
Hayward Navigator Pool Cleaner Logo
557 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
