Question about Rockford Fosgate Car Audio & Video
How do u remove the P2 magnet cover? it says in the manual its removable
    Sniper:
  • 58 Answers
If you have the 2004-2006 model P2's the cover actually pulls right off, it is held on magnetically.
2007-2008 you break off the silver piece (pole vent cover?) that says RF on it. its glued in. then the actual cover itself is screwed in.
NOT SURE WHICH ONE YOU MIGHT BE REFERING TO.
Hope this helps.
Posted on Nov 09, 2010
Saeco Magic problem. The magnet rises when I fill the water tank off the machine but, it drops as soon as I make a cup of coffee. To clear, I have to remove the tank and reset the machine. Any help?
hi,
what do you mean by "it drops" ? If it doesn't float anymore, you have to replace it. Remove the top cover of the small tube where the magnet floats, replace the floating magnet and replace the cover.
If the cover doesn't seat properly, glue it with a drop of silicone so you can remove it next time.
If the magnet floats but is not recognized by the inside detector (the small white block you can see inside the machine, in front of the magnet), it is probably because the magnetism has fainted with time. Replace it with a new one.
Hope that helps.
M.
May 14, 2016 | Saeco Magic Comfort Plus Espresso Machine
Tip
How to fix a nokia 5800 blured display
first remove the phone's front and back cover or case (only just remove the front and back cover you dont have to dismantel totally the phone) after removing it put a flat magnet on the top of the lcd beneath the earpiece, make sure that the magnet use is fit when you place back the cover and thats it the display will come back to normal.
on Oct 09, 2010 | Cell Phones
I am trying to run 3xP2 12's and trying to figure out what amp or amps should I use and what type of enclosure should I put them in
250 watt subs x 3 = 750 watts RMS those are sony explodes (RF P2) hidden in a big magnet cover. get rid of them garbage
Apr 06, 2015 | Car Audio & Video
Manual se 5010
If you removed the black shuttle cover please put it back. If you removed the cover and dropped the magnet on the right hand side then please find and replace.
May 12, 2014 | Printronix Office Equipment & Supplies
Portable AC model # LG 1010SNR. There is a message(P2) on the screen and it will stay on for more than a few seconds.
Easy easy!
Remove the batteries and put it again now your remote will function properly. Regarding P2, it means defective air senor. replace it.
Aug 17, 2012 | Heating & Cooling
Removing timing gear on 1988 buick reatta
Without writing a book, jack up the car and remove the passanger side tire...best access via the wheel opening...you must remove the harmonic balancer, water pump and timing cover to replace the timing gear. Unless you have lots of miles they go a long time.
The cam magnet is behind the cam sensor, remove it and manually rotate the engine until the hole in the cam is visible. You might find the old magnet. Clean out the hole, glue in the plastic holder and magnet.
May 03, 2012 | 1988 Buick Reatta
How do i stop lights going on on door opening ?
If your fridge has a manual door switch which gets pushed when door is closed, then you can tape up the door switch.
Some fridges have a magnetic sensor, so you can cover the sensor with a magnet.
Failing those you can remove the light globe.
Sep 11, 2011 | Refrigerators
The bottom part of the cover for my oil tank fell into the oil tank. Is there a way to remove the cover to get it out without removing the entire oil tank?
I'm not familiar with the cover you're talking about. If it's made of metal, you may can get it out with a magnetic tool retriever. If it is not magnetic, you'll have to remove the tank.
The tank is not difficult to remove. I think the tank has three bolts and you'll probably have to remove the battery tray on the other side. Disconnect the hoses and remove the tank.
Good Luck
Steve
Aug 10, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
Hobart AM15T ML-130039 with p2 message, what does this code mean
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
Jan 29, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Removing photos
just connect it to ur computer, open it through my computer, and manually delete it..... OR u can go to SMS or Emodio, and delete it from ther!
Jan 19, 2009 | Samsung Yepp YP-P2 Digital Media Player
Car Audio & Video Logo
357 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
