Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
98 Fatboy backfiring through carb, not enough power on take off, through second gear seems to lag with not good pick up. Everyone takes off and leaves me, takes me a bit to catch up. Everything is stock on the bike other than Vance and Hines long shots and a K&N air filter. Any suggestions?
  • 23 Answers
SOURCE: 1997 FatBoy backfires through the carberator.New
Carburator backfires are almost always due to a lean condition. Check your intake manifold for air leak. Star the bike, warm it up and let it idle on the kickstand. From the air breather side spray a bit of wd40 onto the intake manifold (one side at a time) and listen for the idle to pick up. If it does, you're sucking air around the intake. This should be fixed right away as it will just get worse and could result in burned valves. If this is not the case then check the main jet in your carb and get one that is richer. Trial and error is the only way to determine the best jet for your bike.
Posted on Aug 20, 2009
stephensaon_
  • 284 Answers
SOURCE: 2007 night train vance & hines pipes &
It probably isn't oil, it's more than likely fuel mixed with carbon due to running too rich. check your settings on the fuel pak.
Posted on Aug 27, 2009
Pristonero
  • 119 Answers
SOURCE: 2003 Ultra Classic engine backfire when upshifting
go to basics replace the sparks
Posted on Oct 20, 2009
wd4ity
  • 4565 Answers
SOURCE: Mikuni jetting
If it's the Sreamin' Eagle Mikuni, it should come jetted close enough to take your bike to someone with an exhaust gas analyzer. That's the best way to get your card jetted correctly with the extensive amount of changes that you have made on this bike. I would advise that you take the bike to someone that has a dynometer that is equipped with an EGA and have the run the bike up. I would not want the mixture to exceed 14:1 at any time and preferrably run about 13.5:1. It's a bit on the rich side but it will help keep your engine running cooler. I've installed the carbs before but I cannot remember what jets they had in them. Sorry. Good Luck.
Posted on Jan 22, 2010
Testimonial: "I appreciate your quick response to my question. Unfortunately,I live on an island and I don't have much choices."
ultrat
  • 500 Answers
SOURCE: 2009 MODEL FLHTCU WITH: K
Settings ?? TFI .. I have same bike K&N ac wild pigs 2 1/4 bafle dealer down load my settings 2.5 ..3..4.... I hear burbling not backfiring .. I have welded a splitter at end of baffle ..
Posted on May 05, 2011
No power when give it gas.
believe carb adjustment bad & carb needs to be rejetted to exhaust, believe you need to add a higher flow gas valve & possibly new plugs & wires
Apr 21, 2014 | 2000 Harley Davidson FLSTF Fat boy
99 fatboy has no power
Hi Anonymous, you have all the classic symptoms of retarded timing, bad intake seals, and incorrect clutch adjustment, or wrong type of primary oil, or contaminated and or warped clutch plates. Good luck
Apr 19, 2014 | 2005 Harley Davidson FXSTI Softail...
2010 FATBOY WHILE RIDING LOSES POWER FOR A SECOND THEN BACKFIRES THEN REGAINS POWER
If you have changed exhaust, air filter even slip ons you likely need a different modules setting or if a carb it needs jetted. My bike always "burped " until I changed over to a S&S, drastic but builder explained that slip ons and K&N changed enough to cause the burp
Nov 11, 2013 | Harley Davidson Harley-Davidson Motorcycle...
2002 VStar 1100, sat for six months to a year with staybilt in the gas. I am prospective buyer. The bike has Cobra Shotgun pipes. To begin with it ran very poorly but cleared up to about 85%, but...
Without being there to listen to it, I would guess that you probably do have a carburettor issue. One of the carbs is not functioning properly causing a serious lack of power. The backfire at deceleration is most likely caused by leaks in the exhaust system, but could also be caused by an over fueling carb. I would remove and clean the carbs, pay close attention to the pilot jets and their circuits, (the pilots plug easily due to their small size), make sure the float needle and seat are clean and there is no noticeable groove around the tip of the float needle. Do not change any of the linkage or their related adjustment screws or you will need to re-balance,(synchronize), the carbs. Re-assemble and test. The oxygenated fuels that we are using these days will go bad in a short period of time, (weeks or months), even with a good fuel stabilizer. The most common fuel related issues that we have seen in the last couple of years has been plugged pilot jets and float needles with corrosion built up on the sides of the needle that cause them to stick in needle seat. We recommend using one of the fuel additive products that are on the market now that help to keep the insoluble particles suspended in the fuel so they can't congeal in the carbs.
Nov 16, 2010 | 2001 Yamaha V Star 1100 Classic
1997 FatBoy backfires through the carberator.New carb.
Jul 08, 2009 | Harley Davidson Harley-Davidson Motorcycle...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Does my 360 have a disc drive issue?
The lag you're experiencing most likely isn't the result of any physical abnormality, but rather you're network. How many people in your household share the same network? The more people on a network, the slower it will run. (I've actually experience this first hand) You might have too much people sharing your network for your game to run smoothly. Try to go on hours that everyone is not on. As for the repeated starts and stops, during game play, don't stress that. Its normal.
Jun 20, 2009 | Microsoft Xbox 360 Console
Having trouble keeping my 98 jeep grand cherokee running
i recommend cleaning the throttle plates. they are located unter the intake hose form the engine to the air filter housing. if you open them with the engine not runniong you will see they will be covered in carbon. use a good carb cleaner and a rag to wipe them clean
Jan 20, 2009 | 1998 Jeep Grand Cherokee
98 Dodge truck...
Sounds like the alternator isn't running good, have you tested this? Perhaps it isn't sparking cosistently and the loss of power would be explained if it isn't kicking out enough power.
May 20, 2008 | 1998 Dodge Dakota
Lands Phones Logo
147 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
