Question about Sangean ATS 818 AM/FM/SW Radio
I HAVE A RADIO SHACK DX-390 RADIO. MY PROBLEM IS IT WILL NOT RECIEVE STATIONS ON ANY BAND. THE SPEAKER AND COTROLS DO WORK PROPERLY HOWEVER, I HAVE HEARD THAT THIS IS A COMMON PROBLEM DO TO STATIC. WHAT WOULD BE THE CAUSE AND HOW CAN I FIX IT?
How so i pick station on my Radio Shack police scanner?
I have never used a scanner of that type but I have seen them in use and know the principle of operation.
If you are certain the radio is working and have checked with the instruction manual that you are operating it the correct way with any squelch control turned down and the volume turned up there should be a loud hissing from the speaker indicating the radio is ready to receive as soon as it is either tuned to the specific frequency of a station by direct entry or by scanning one or more bands of frequencies.
If there is no hissing noise it is possible the audio output is faulty or the aerial is not connected or the radio is otherwise faulty.
If the hissing noise is present and powerful and still nothing is being received it is possible there is nothing to receive or a more powerful aerial is needed.
It is worth noting many scanners available in the past tended to scan bands of frequencies in the upper and lower vhf bands where the aircraft, marine and emergency services radios operated. Since those days many of those services have moved their communications into the UHF bands leaving the vhf bands relatively empty.
Oct 04, 2015 | Radio Shack Radio Communications
Looking for user manual for Radio Shack EC-398 calculator
http://www.manual-archives.com/dx-398-all-band-shortwave-receiver-SM-L14987.html
Jul 17, 2011 | Radio Shack Office Equipment & Supplies
CB RADIO TRC 446 WILL NOT RECEIVE
IF YOU CANT RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Jan 29, 2009 | Galaxy Radios DX-99V 40-Channels Base CB...
1998 Wrangler Sahara - radio not recieving low freq FM Bands
if you are receiving stations on the higher frequencies then your radio is the problem and not your antenna or anything else
Jan 13, 2009 | 1998 Jeep Wrangler
Pioneer-vsx-9500s radio won't work with cable
You cannot plug cable from the wall into a receiver, you will blow the tuner card.  Use the supplied antenna or go to radio shack and ask them for an fm antenna.
Jan 04, 2009 | Pioneer VSX-D509S Receiver
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
JVC RX 809V home reciever
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Aug 08, 2008 | Audio Players & Recorders
Dx-88 HL
You'll need to take it to a repair shop. Because it transmits its under FCC rules so a certified tech needs to work on it.
Or take it back to where you got it and have them correct the problem.
Dec 29, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Pro-97 scanner recieving problem
try going to a urban area and scanning the NOAA band. if that works your programming is wrong and there is nothing wrong with your AM/FM base band. also the BNC antenna connector on the inside is notorious for breaking away from the board, nothing a little solder cant handle. Also make sure your local freq's are not Digital
Dec 05, 2007 | Radio Shack Pro-97 Handheld Scanner
Sangean ATS 818 AM/FM/SW Radio Logo
193 people viewed this question
Top Sangean Audio Players & Recorders Experts
Pete Vernall
Level 1 Expert
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
