Question about Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator
STOPPED WORKING- EVERYTHING IS DEFROSTING - Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 09, 2010
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
ED5NHGXMQ00 stopped working overnight. Ice maker
Clicking could be a bad starter relay if the noise is coming from the back under the unit where the compressor is. check it here Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
The clicking could be coming from a fan, one of which is near the compressor under the unit and another is in the freezer behind the rear cover inside.
The defrost timer could be clicking. This sound would come from the fridge. Part 6 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ED5NHGXMQ00&productCategoryId=0165000&brandId=1198&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00011&componentDescription=CONTROL%20PARTS&documentId=W0309019&backToLink=Return%20to%20Sub%20Components%20list
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Side by side refrig. side not working;freezer freezing up
The unit is not defrosting. Either the defrost clock is defective or the defrost heater is not working. Defrost clock is normally located behind the bottom kick panel. Use a large standard screwdriver and turn the center screw clockwise very slowly until the compressor stops. Wait 20 to30 minutes the compressor should restart, if not the defrost clock is defective. Checking rhe heater you'll need a vom meter or amp meter.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge never stops
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 11, 2009 | Kenmore 53082 / 53084 Side by Side...
Frige and freezer will not get cold .would vent in freezer being block cause this
No that would just affect the fridge.
Make sure freezer fan is working. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
Sep 10, 2009 | Refrigerators
Frost free freezer icing up
It should still be covered under the warranty.
Sep 02, 2009 | Amana ATB1832AR Top Freezer Refrigerator
The refrigerator part stop getting cold, but freezer part is still working, what do i need to do
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 30, 2009 | Kenmore 57029 Side by Side Refrigerator
EVERYTHING WORKS FOR ABOUT A MONTH AND THEN THE FREEZER HAS A BLOCK OF ICE ANT THE BACK AND THE BOTTOM BECOMES WARM
Aug 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer working fridge not
There are screws around the edge to remove it. It's probably iced up due to defrost system failure. How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Open Questions:
Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator Logo
158 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
