Question about Kyocera Mita Office Equipment & Supplies
I have a kyocera kn3035 the copies come out light tried making them darker up to +7 didn't help any went into management side with a +3 and a +7 didn't change any. Any Help on what to do next would be great or what is wrong? Thanks Brad
Km-4035 kyocera copier
Does anyone knows where i can buy the two hooks that the transfer roller gets clipped into?
Posted on Jun 15, 2012
  • 165 Answers
Check the transfer roller my guess is that clip that holds it in the psn brocken and u have no transfer.(gray roller when u open the left hand door)
Posted on Nov 13, 2010
Copy is not dark
You need to either change the toner on your copier or change the settings so it makes it darker.
Jun 09, 2014 | Kyocera TASKalfa 180 Copier
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Bottom of the copies are darker than the top I
There may be spilled toner inside the copier, Free the drum and paper way of toner an ensure the toner container is not over full. do proper cleaning and the copier will be okay.
Jun 10, 2010 | Kyocera Mita KM-2050 Printer
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
Changing number of copies a person can make.
Hi
The universal password for Kyocera copiers is 6482 but only when you have gotten past the first password (if you have set one)
You need to go into MANAGEMENT area and set limits for each person.
Hope this helps
Feb 27, 2009 | Kyocera Office Equipment & Supplies
I have problem while copying with my kyocera mita km-1635
If its on the rear side of the page would most likely to be the transfer unit. What model is the machine?
Thanks Jason
Aug 17, 2008 | Kyocera KM-1510 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Sharp AL-1340
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Apr 12, 2008 | Sharp AL-1641CS Laser Digital Copier
67 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
