Question about MSI P965 Platinum (7238010) Motherboard
I have bought a 2x2 gig ram upgrade from 1 gig for my computer. I have an msi p965 motherboard where should I plug th two ram modules into. I have a choice of two orange or two green inputs? what are your thoughts Best regards Steve
  • MSI Master
  • 5,660 Answers
Steve, the ram memory slots are coded in a color.
Two ram memory slots of the SAME color are One Channel.
Use one Green ram memory slot, and one Orange ram memory slot, enables the ram memory to be Dual Channel.
[NOTE*
IF, the ram memory modules are the SAME.
Same density
Same ram timings
Same voltage
Same chip configuration
This is why two ram memory modules are usually purchased from the same ram memory manufacturer ]
For example;
The ram memory slot that is closest to the Processor socket.
This is ram memory Slot 1.
(DIMM 1)
The next ram memory slot over is also Green. This is ram memory Slot 2.
They both use the Same Channel.
The next ram memory slot over is Orange. This is ram memory Slot 3.
Ram memory Slot 3 is on a different channel.
Use Ram memory Slot 1, (Green), and ram memory Slot 3, (Orange) for your 2GB sticks of ram memory.
(Use ram memory Slot 2, and ram memory Slot 4 for when you obtain more ram memory)
Using two different channels will make the ram memory operate in a Dual Channel mode.
The theory is that using ram memory in a dual channel mode, will make the ram memory modules, ('Sticks') piggyback off of each other.
One ram memory module is handling part of one task, the other ram memory module is handling the other part of the task
This was though to greatly speed up ram memory performance.
Supposedly up to 30%. (30 percent)
However it was only on paper. Only theory.
It has been found through repeated exhaustive testing, that this is fictitious.
The ram memory performance only increases from 1 to 2 percent.
Why do big time gamers use dual channel configuration for their ram memory?
1 to 2% gain in performance, lol!
They want all they can squeeze out!
To add;
http://www.pcstats.com/articleview.cfm?articleid=2049&page=3
Posted on Nov 09, 2010
  • joecoolvette
    joecoolvette Nov 09, 2010
    (Bullsticks!)
    Sheesh!
    The motherboard will support EITHER DDR2 Sdram at 533MHz, OR DDR2 Sdram at 667MHz, OR DDR2 Sdram at 800MegaHertz!
    If you use ram memory that is of different speeds, (Frequency Rate), BIOS will clock the ram memory speed down, to what the slowest ram memory module is.
    DO NOT use 533MHz ram memory, AND 667MHz ram memory.
    DO NOT use 533MHz ram memory, AND 800MHz ram memory.
    And so on.
    Use the SAME speed of ram memory in the ram memory slots.
    Again,
    Use one 2GB ram memory module in ram memory Slot 1. (Green. May state DIMM1 next to it)
    Use the other 2GB ram memory module in ram memory Slot 3. (Orange. May state DIMM 3 next to it)
    Genius:
  • MSI Expert
  • 1,325 Answers
Hello :)
there are several mainboards , select the one that is yours ..make sure you have the correct memory modules (DDR2 533/667/800)
two slots are DDR2
two slotrs are DDR3
go to this link and review information about your specific board
http://us.msi.com/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=1275
i hope this serves you well :)
  • MSI Master
  • 27,725 Answers
Put the largest ram closest to CPU central processing unit make sure that the ram are of the same brand/type some motherboards only accept a certain brand/type
K9N6SGM-V I have a 2 Gig ram and i installed a extra 1 gig so its 2gig + 1 gig = 3 gig .and my computer wont boot
some types of ram are not comatible with othres always try to keep them ofthe brand /type
the larger ram should be in the socket closest your CPU central processing unit
if these are not requirements are not followed your comuter willfail to boot
hope this helps you
Oct 06, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Hi, i used to have 1 gig ram . recently i bought 2 gig ram both has 667 Mhz of speed the prob is that pc is not booting up with 2 gig in combo or alone is it problem with the bios please help
Hi
This is DDR2 RAM for a motherboard that takes DDR2 RAM.
It is more likely that the RAM is incompatible. Check the correct RAM specification range for *********** board.
Also some RAM is Error Correcting and this might not be compatible with your motherboard. Most PC motherboards take non error correcting RAM.
If not, the RAM may be faulty. Most RAM has a lifetime warranty, so you should be able to return it.
To clear the BIOS memory, disconnect the power cable and remove the small silver CMOS battery for 2 ninutes, then reintstall the battery, reconnect th epower and test again.
I hope this helps.
Aug 26, 2011 | Computers & Internet
HI, i was thinking about upgrading my laptops ram module for faster use, i am not all to computer savvy, i just play games and use the inernet. i was wondering how i would install the module and use it...
In laptops, (and some desktops) how much RAM you can use is dictated by how many slots exist to plug ram into. Also, by how many Gigabytes are supported by the motherboard chipsets.
For you... You probably have 2 slots for RAM. IF you have 1 GB of ram, it may be in 2 sticks of 1/2 a gig (500 MB each) plugged into the 2 slots. Or if you have 500 MB, 2 sticks of 250MB This is very common.
If you want to upgrade to 2 Gig, for example, (and may be the max for you) you must purchase 2 sticks of the correct type to install, and remove the existing sticks. You may be able to sell the old ones on ebay.. but hardly worth it for few dollars.
Most important is to reseach exactly what your laptop supports maximum and the correct type.
For more help, post a new problem with specific laptop info. Manufacturer, Model number etc.
Aug 10, 2011 | Computers & Internet
I have intel d845gvs1 motherboard with P4 2.4 ghz, Currently have 2 ram (512mb & 256 mb) how much further can i upgrade the ram, 1GB or 2GB also is the current combination of ram is right?
"Supports up to 2 GB of system memory with DIMMs utilizing 512 Mbit
technology DRAM devices"-intel
you can use 2 sticks of 1 gig apiece to get to 2 gigs of total memory, but you have to make sure that the ram sticks use "512Mbit " technology.
the 512Mbit technology refers to the arrangement of memory chips on the ram cards. a card which uses 64Mx8 (8 seperate memory chips of 64M apiece) would be appropriate.
"Nearly all motherboards only recognize 1 GB modules if they are low density 64M×8 modules. If high density 128M×4 1 GB modules are used, they most likely will not work."-wikipedia"
Oct 27, 2010 | Intel D845GVSR Motherboard
2 gig ram sticks
Not with Windows XP, because more than 3 gigs isn't useful. Many servers come with 8 or more and nearly any computer you configure at the major manufacturer's websites can be bought with 8 or more.
Sep 19, 2009 | ASUS P5VD2-MX SE Motherboard
Memory
if it is windos xp then it wont recognise
Feb 08, 2008 | Computers & Internet
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
MSI P965 Platinum (7238010) Motherboard Logo
530 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
