Question about Samsung Televison & Video
I have a 2004 Samsung HDTV 1080i that all of sudden won't turn on. When I push the power button on the remote or manually on the set, I can hear it begin to power up, but before it completes powering up, it shuts itself off again. We tried several time to get it to turn on - even unplugged it for a while and tried again, but it still does the same thing.
    Problem Solver:
This could be a number of things but the simplest of all is to check the Lamp inside the back of your TV set. You will have to remove the back cover to do this and since you have a Projection TV, your Operations Manual should describe this procedure in detail. These lamps only last for about a year before they start going bad. Try that and if it still doesn't turn on, I would suggest changing the Lamp-Ballast which is a little more involved. Also, check your Color-Wheel. The Color-Wheel is a mechanical unit rather than electronic and is subject to bearing failures as well as heat stress. If all of these prove good then I would suspect the Power-Supply which is usually a job for a Technician. Before we get into a lot of detail, check your Lamp first and replace it if needed. If the TV still doesn't turn on as expected send another post and I'll try to walk you throught changing the Lamp-Ballast. Please include your model number.
Posted on Nov 09, 2010
I have a Sony NSX-40GT1 that won't power on. You can hear the relay click after plugging in, and the red power led comes on, but when you push the power button it does nothing. Any ideas?
I'm having the same problem. Can anyone help. If possible i'd like to fix it rather than go return it. It worked fine for a while and then suddenly started turning itself off. Now every time i turn it on it turns itself off.
Jun 12, 2011 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
Where is the valet switch on a 2004 chevy malibu LS?
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings - Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
Feb 17, 2011 | Keyless Entry Remote Fob Clicker for 2004 ...
I have a samsung hdtv 1080i that has sound but no picture
It means you covergence setting not ok.use remote press (mute183) set covergence lines remember before you save these setting press self focus botton in remote and exit by smode
Jul 24, 2009 | Televison & Video
PS3 display problem for multiple TVs
try to do a simple reset it will reset your video settings just turn it off then hold the power button then KEEP HOLDING until it beeps 2 times then it should come up note: it will not delete any of your data
Mar 04, 2009 | Mitsubishi WD62627 62" HDTV
1080p to 1080i
Use the original composite (yellow, red, white) cable that came with the PS3 and connect to a composite input on the TV. This way you can see the setting for the PS3 and make your changes. Hope this helps
Dec 24, 2008 | Samsung DLP HL-P5663W 56" TV
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Jun 04, 2008 | Televison & Video
No power to HDTV
Call for repair, the set is under warranty.
Feb 19, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help with getting it to work
Sounds like a power supply issue. Is the set new?
Jan 28, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
293 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
