Question about AMD Codegen 350W ATX P4 Recommended Switching Power Supply, OEM Package (dscgps350atx) Power Supply
My Codegen Switching Power Supply 350W Model 300Xi is smoking when I turn on my PC, a big cloud of white smoke when I turned it off.
    President:
  • 2,992 Answers
There's obviously something wrong in the supply, but it's not worth trying to repair. Replacement cost of computer power supplies is so low that there's no reason not to just throw it away and install a new supply. The time spent in trying to troubleshoot the problem and cost of parts will certainly exceed the price of a new supply.
Posted on Nov 09, 2010
I getting loud annoying sounds from my CODEGEN ATX2 switching power supply I think its the fan should i replace the power supply and is it affordable to have it done?
Yes you should replace the power supply and you can do it yourself go to the back of the tower and at the top you will be able to see the power supply it is held in with 3 to 4 screws open the side panel and unplug all the wires that go from the power supply to the different components of the computer
then unscrew the power supply from the back of the tower and lift it out you will need to get a ATX
P4 power supply you can get the best price at new Egg ,or Amazon .com the prices very in price from 30.00 to a Hundred or more
Sep 01, 2011 | AMD Codegen 350W ATX P4 Recommended...
I have presently a atx 350w power supply would yours solve my supply problem
If your ATX switch mode power supply is faulty then I suggest you replace it with a new one that is 350 watt or higher wattage.
Fixing faulty ATX power supplies is not a DIY project, there are dangerous voltages in these power supplies and can cause death or serious injuries.
Jan 30, 2011 | AMD Codegen 350W ATX P4 Recommended...
Whenever I start the car it smokes than after warming up it stops smoking.
The key is how much smoke? Does the smoke have a smell to it. Are you consuming any fluids, like coolant, or oil?
Tons White smoke that is sweet smelling is usually coolant getting into the combustion chamber.
Less white smoke, especially if other cars are doing it, is normal. For every gallon of gas that you burn, you generate a gallon (GALLON) of water. so this water usually evaporates, but sometimes not. It has little or no smell.
If the smoke is bluish white, that is oil, but usually your converter would fill with oil, and cause error codes, or loss of power. This smell is distinct, but not necessarily sweet.... After the converter heats up, it may be able to burn off the oil and the smoke stops.
What are you consuming, fluid wise, will direct where you go next.
Jan 27, 2011 | 1995 Lexus LS 400
My Codegen Switching Power Supply 350W Model 300Xi Atx2 o3 (P4) is smoking when I turn on my PC
Using 115 volt or 208 volt switch?Found on back of supply
Is the fan clog with dirt and is it turning?
Check your wiring as some supplys can be wired for 115 volt or 208 volt.you want 115 volt.
Jan 16, 2010 | AMD Codegen 350W ATX P4 Recommended...
Heater smokes but doesn't turn on
It sounds like you have a dirty nozzle. Remove and replace with the same type. It may not be spraying a fine enough mist.
Hope this helps.
Matt
Jan 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
350w switching power suply
Michael
at first chack at which time it shutting down. if it happen when u click on any drive or when u using cd/dvd drive then power supply cant regulate power. then chack switching transistor and filter section capacitor.
(Be careful about filter capacitor in primary section because some time it stored high voltage dc after plug of power supply at first discharge this two capacitor.)
** also chack supply voltage r stady or not.
Jun 26, 2008 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
AMD Codegen 350W ATX P4 Recommended Switching Power Supply, OEM Package (dscgps350atx) Power Supply Logo
166 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
