Question about Dayton (3E379) Heater
I have a wall furnace with a 2 wire thermostat system, 1 wire from the 24v transformer & 1 wire goes to the gas valve. I have a Dayton 1uhg7 wireless thermostate that has heat & cool & several day programming. Can this thermostat be wired for a 2 wire system for heat only. The directions are not compatable to a 2 wire system. Is there possibly something else I need?
3 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Posted on Oct 31, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: installed dayton nat gas hanging furnace in garage
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Posted on Dec 11, 2009
Furnace does not start
Furnaces usually have a high temp limit switch that turn off the gas if the plenum gets too hot, as it may if the fan fails (or air flow is restricted) and the furnace is running. These are in series with the gas valve so if they fail open will prevent the furnace from ever turning on.
Trace the circuit from the transformer through each component (including the thermostat) and check for an open circuit at each location. Replace the one that has an open circuit.
Also check the fan to be sure it is working properly when you directly connect power to it.
Mar 10, 2017 | Heating & Cooling
How do you wire the thermosat on williams wall furnace model 3509622
This heater has 2 type gas valves one valve has the thermostat built into it. No wiring needed for that puppy. Looks like this:
So I am guessing that one ain't you.
Your heater must use a millivolt gas valve with the 2 wire wall thermostat. The pilot generator does 2 things. It holds the pilot on and it produces voltages that operate the solenoid and open and close the valve when the room thermostat makes contacts. So what goes wrong with these? The pilot generator will sometimes hold the pilot flame but whn the 2 wires are touched together or you tun on the wall thermostat the whole thang just dies. That my friend is a weak thermopile generator. The other thang that goes wrong is the solenoid on the gas valve is open and therefore the gas won't come on. Their is also a fuse mounted on there that melts and kills the magnet that the generator holds in for the pilot.
Nov 04, 2011 | Williams 2509612 Ceramic Mid-Size Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Installed new gas valve. Wired according to instructions with valve. Shows 3 wires coming from igniter to gas valve. 2 tabs on valve above pilot. Burners won't come on.
I need more info to help you out. You need to check if there is anything else wrong with the furnace. But a for the gas valve goes you nee to check if your geting 24 volts to the gas valve. The pilot sensor might be bad. What kind of gas valve do you have. are the three wires coming back to gas valve Yellow, White, and Green. If they are most likly its the flame sensor not the gas valve.
Oct 07, 2010 | Dayton Gas Furnace Heater
How to attach the wire to the wall heater(gas)
Well you need to post what wire you need to attach to the wall heater. Im assuming its the thermostat. There should be only 2 wires one goes to the gas valve and the other goes to the sensor inside the furnace. the thermostat only need to be connected to R and W. Please Post more info to help
Oct 06, 2010 | Heating & Cooling
How to install and wire thermostat on model WOBC 095QBEA fuel oil furance
is this the 2 wire valve on the furnace, if so i'm pretty sure it's a 24 volt setup, check on valve it should say,there will be a 24 transformer,the valve or relay and a thermostat,one wire from 24 volt side of transformer to valve,other wire from transformer goes to R on thermostat,other wire W from thermostat returns to connect to other terminal on valve or relay if it's forced air, sure hope this helps
Jan 31, 2010 | Heating & Cooling
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Do i need a low voltage transfomer to hook up my
what kind of thermostat to you have, did you purchase the thermostat with the unit are you upgrading to a electronic thermostat, If you are using the mechanical thermostat that comes with the unit you will not need a thermostat. please see the link below and page 11
http://www.wfc-fc.com/pdf/Monterey_Top_Vent_IOM.pdf
Jan 17, 2010 | Honeywell Programmable Thermostat Heater
Installed dayton nat gas hanging furnace in garage and have 2 wires dont know where they go one came from the back side of the transformer it was twisted with the other wire
Dec 11, 2009 | Dayton Gas Furnace Heater
I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Dec 08, 2008 | Dayton 511 Utility Heater
Dayton (3E379) Heater Logo
554 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
