Question about Flotec Electrical Supplies
Hey, I just had a Flotec Series FP4300 installed for my well and the manual says that it should go to 50psi and turn off, but the pressure gauge stays at 30psi and does not go any higher so it just keeps running. All the faucets are closed and I don't see any pipes leaking. Is there a way to adjust the pressure switch? Dave,
  • 4 more comments
  • Daryl Gleaton Mar 29, 2014
    Ok, upor tank has a bladder inside. the bladder has a valve stem simalar to a tire vavle stem on you car. The bladder is supposed to have 12 PSI to 15 psi pressure in it. Check the pressure with tire guage. I f the pessure is right the pump will not come om until the pressure is lower than the bladder pressure. Adjust pressure switch to maufacturer recomended setting. I have had tanks tha the bladder inside is stuck together, in this case the tank top needs to beremoved and then one would have to pull the blader open by hand.
    Yes, the previos post can also cause low pressure. The jet valve could be leaking. Also adjust bladder pressure to 28 psi, I gave you a ball park stting that is for a smaller lower preddure pump. Hope this helps. Good luck I will check back to see if this fixes you problem.
    Sorry for the typos, just found my glasses, it's hell getting old, but it beats the alternative. !!!!
    The pressure switch adjistment is inside the little black box where the electrical cord goes to the pump, remove cover nut and adjust the small nut with the spring below it.
    Clockwise to increase pressure, but I amm going to check the manual for your pump to make sure I am giving you the proper advice. Different pumps will sometimes have alternate pressure adjustments.
    Ok, Just one adjustment in the electrical box. One full turn equals- 21/2 psi, so you would need 8 full turns to raise to 50psi.
Http://www.depcopump.com/datasheets/flotec/FP313-EN.pdf
Maybe your check valve is letting water go back down the well.
Troubleshooting steps pg 13 in manual list several things.
Check air valve for leaks.
Flowtec has a customer service number:
1-800-365-6832
The manual says: "Your new pump has a 30/50 PSI
switch, so adjust the tank pre-charge pressure to 28 PSI.:
But the manual does not say or show how to adjust pre-charge pressure.
The 30/50PSI means the pump turns on when pressure falls to 30, and then runs until pressure rises to to 50. So the switch is preset and not adjustable.
Posted on Nov 09, 2010
  • 656 Answers
Yes, the previous post can also cause low pressure. The jet valve could be leaking. Also adjust bladder pressure to 28 psi, I gave you a ball park setting that is for a smaller, lower pressure pump. Hope this helps. Good luck I will check back to see if this fixes your problem.Ok, Just one adjustment in the electrical box. One full turn equals- 21/2 psi, so you would need 8 full turns to raise to 50psi.
I have also had bladders that were stuck and folded over, this also can cause a low pressure reading on the guage. If this is the case then you will have to take the top off the tank and unfold/unstick the bladder and recharge to 28 psi, or the pressure that your manual suggests.
Posted on Mar 29, 2014
Pump body and bracket position bolt mount repair.
lol too much power for the pressure tank back off the flow or get a new pressure valve 50 psi is good pressure how big is the tank what is the gauge rated for all these \details need to be spoken in order to answer sounds like you want some water lol its sucking air too tank doesn't need air it has to be primed first tighten the bolt and now you have to use pipe sealant white putty to seal those nuts and bolts back up pump cant suck air
Feb 28, 2017 | Flotec Plumbing
How can I tell if my oil pump is bad on my 2004 GMC Yukon
You hook up a mechanical oil pressure gauge at the oil pressure sending unit oil port and test the pressure, it should be about 25 PSI hot idle and about 50PSI at 2-3,000 RPM.
Aug 29, 2012 | Cars & Trucks
Have Flotec pressure tank style fp7120-08 .Pressure gauge with nothing running goes up and down constantly. I've drained the water in house shut off power to holding tank znd there is no pressure
check the foot valve for leaks it at the end of the pipe in the well also if its newer than 30 years there is a cupler where the horizontal pipe meets the vertical on at the well head
Apr 24, 2012 | Plumbing
I have a flotec 1 hp pump model number fp5162-08 hooked up to a 30-50 blader tank suppling two hose bibbs suppling water to two hoses with manuel sprinkler heads. The pump will not pump more than 34psi to...
I am going to take a stab at this it sounds like the bladder has gone bad it the expantion tank. Try letting some air out of the bladder tank and see if you get any water if you do then the bladder has gone bad the tank will need replaced. After the replacement turn the limit switch back to normal settings. You can also tap on the tank to see if it is full of water.
Feb 09, 2011 | Flotec Plumbing
I replaced old pump w/ Flotec 1/2HP FP4012 and replaced old pressure tank w new 35gal tank. Pump primed but cycles on-off every minute constantly even w/ no water turned on. Goes to 50PSI, loses pressure...
The water and therefore the pressure has to be going somewhere. If you are sure that there are no leaks in the house or outside, then the water is going back into the well. There is a check valve either in the suction line of the pump between the top of the well and the pump or down in the well.
If this check valve fails, it allows water to go the wrong way and back to the well. The result is that you lose pressure.
Secondly, you have to be sure that there are no air leaks between the top of the well and the inlet to the check valve. Leaks in that piping will make repriming difficult.
Write back with more and I'll try to help more.
Gary
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a 1HP flotec submersible at 130 ft. It is a replacement for an older pump that went bad and is about 8 years old. Yesterday the breaker triped. I turned the breaker back on and it triped after a few...
It could be you have an obstruction in water flow. Are you sure your check valve is correctly installed ( not reversed ). If there is no check valve you might want to install one. A quick way to find out is to use an amp meter and monitor the amps. If it goes beyond the F.L.A. on what the pump is designed for and does not come back to norm after a few seconds, than this is what is probably happening. Be safe and always call an electrician.
Jan 19, 2011 | Flotec FP217811 Submersible Well Pump...
What preasure should it stop pumping
It is factory preset to stop at 50psi but is adjustable. Do you have a pressure tank in line and close to the pressure switch to assist in pressure stabilization?
Nov 08, 2010 | Flotec TC2151 P2 Well Pump Pressure Switch
Pump will not shut off gives great pressure when running how do i fix this?
This pump runs off of a pressure switch either 30/50PSI or 40/60PSI. It would appear the switch has failed and will need to be replaced. Any Square-D pressure switch will do, head to a home improvement stire and they should have the right item for you. It will cost you @ $10-$15.
Please let me know if this had assisted you,
Tom
Apr 21, 2010 | Flotec Corrosion Resistant Shallow Well...
What is the normal oil pressure on a HD 2005 Heritage Springer?
hello you didnt say what oil you run (weight 10-50 20-50 conv, or synthetic) as a average pressure at idle as low as 10psi and running down the road as high as 50psi
Dec 30, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Electrical Supplies Logo
419 people viewed this question
Top Flotec Electrical Supplies Experts
 Kenneth
Kenneth
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
