Question about Apple iPhone Smartphone
Phone doesnt ring only vibrates - Apple iPhone Smartphone
I had the same problem - on the left hand side of the phone (not the screen) if there is a red dot showing you have switched your phone to silent. Click the switch and your phone will ring
Posted on Dec 02, 2008
  • a crossland Apr 27, 2012
    you are an absolute angel
    hubby got me this phone and i have to say i love it ,so easy especially as i am gatget phobic lol
  • 87 Answers
I think you have it in silent mode... if not try changing the ring tone.. it might be corrupted
Posted on Jun 16, 2008
I phone 4 it doesnt ring in or ring any alert sounds
Check the left side of the phone, there's a little switch, if you see red under the switch, click it the other way. Problem solved.
Feb 01, 2013 | Apple iPhone 4 I.D.rubberize Hard Case w/...
How do I get my phone off "mute" to ring audibly
If there are buttons on the side of the phone press the one that goes up, if it doesnt, press the menu button then go to settings and look for something similar to audio/sound
Sep 24, 2011 | Kyocera K325 Cellular Phone
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
I have 3g apple phone i can received calla but so sounds just vibrate
if you mean the phone doesnt make noise when it rings, check the ring/vibrate switch on the left side, and make sure that the volume is turned up all the way when it is set to ring. you can tell when you flip the ring/vibrate switch because onscreen appears either a bell, or a bell with a line through it. if that doesn't do it, you may want to see if your speakerphone works when on a phone call, because i'd say it doesn't and you have a hardware problem that requires contacting apple either at the apple store, or at 1800aplcare
Apr 02, 2011 | Apple iPhone Smartphone
My sony ericson phone w890i doesnt ring out. it only vibrates and when i play music or video from my media they play. but the phone doesnt ring out
Looks like your loud speaker is gone. I buy my parts at flexqueen.com, check if they have it.
However, the fact it vibrates, makes me a little uneasy thinking you might have messed up the setup. I would assume you have checked that before but just in case.....
Nov 29, 2010 | Sony Ericsson W890i Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Thank you for visiting fixya
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Jul 07, 2009 | HTC Touch Pro Smartphone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Pantech c120, stuck on vibrate alert
press the * button and hold it down that should take it off vibrating mode
Dec 28, 2007 | Pantech C120 Cellular Phone
No sound when phone rings
Look at the ring volume. Make sure it's not at zero. Let me know if that works.
Jul 28, 2007 | Motorola Mobility RAZR V3
Apple iPhone Smartphone Logo
338 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
