Question about Life Fitness 9500HR Treadmill
My 9500 hr lifefitness treadmill says speed sensor error
maxtreadmill
  • 832 Answers
SOURCE: treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
Posted on May 21, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: speed sensor error
Your speed sensor may have failed and cause this condition Call Accell Fitness Of North America @ 1-888-388-6887 they are the Tunturi Distributors
Posted on May 06, 2010
jyackle5
  • 8197 Answers
SOURCE: How to adjust the tracking
Please read the link below.
http://www.ehow.com/how_5148912_adjust-belt-treadmill.html
Posted on Feb 15, 2011
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
Tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
9500HR does not come on, where do I start looking for the problem?
I would start by checking the reed switch. Check the gap between the reed switch and the magnet mounted on the back of the flywheel.
LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Oct 09, 2014 | Exercise & Fitness
When running get error message your pressing on the board too hard?
RUN the software calibration for easy diagnostic and fix it. Read you owner manual and follow the steps.
God bless you
Nov 13, 2013 | Life Fitness Lifefitness 9100 Hr Treadmill...
Treadmill speed cant stay above 4km/h
Dear Sir:
Please run the software calibration, for easy diagnose and troubleshooting.
you must adjust the sensor speed see the diagram,
ernesto cuadra
managua, nicaragua. c.a
Mar 08, 2012 | Life Fitness LifeFitness 97Te Treadmill
Speed cant go up.when you increase speed then it reduces by itself
Dear Sir:
Please adjut the sensor speed , and run the software calibration for easy diagnose and troubleshooting.
ernesto cuadra
managua, nicaragua. c.a.
Life fitness 9500 hr full speed at start
Dear Sir:
You must adjust the sensor speed. Run the software calibration for easy diagnose and troubleshooting, and how to calibrate the sensor speed.
Otherwise see my personal TIPS,for diagnose and troubleshooting.
ernesto cuadra
Mar 06, 2012 | Exercise & Fitness
How do i reset the waxer on a 9100 lifefitness treadmill?
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
May 13, 2010 | Treadmill Doctor LifeFitness 9100...
Life Fitness 9500HR Treadmill Logo
478 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
