Question about Casio G-Shock GW500A-1V Wrist Watch
I have a casio g-shock GA100-1A1 and adjusting the analog settings isn't working at all? Their manual states to press A once you're done but its just goes back in reverse to an earlier time. What can I do?
Click through to the world time and choose where you are, if the time isnt right where you are hold down the adjust and it should say dls and then make that say no and then manually config the time like hour n mins and then click mode or adjust again and it should reset, had mine not even a day, got it form a mate who was out afgan, its an awesome watch
Posted on Feb 25, 2011
  • jechko_s
    jechko_s Jun 21, 2014
    I have almost same isue. Firstable it was possible to set the time, alarm and evrything, when I hold the adjust for 2-3 seconds. Now when i click the same button i can turn on/of tha alarm snz and other function, but when e hold this button for 2,4 or 200 seconds nothing happened ?! HELP ME PLS! GA100
How to set time in g shock wr 20 bar
"G-Shock WR20BAR" could mean hundreds of different G-Shock models. If yours is an all digital G-Shock, the answer is fairly simple. When looking at the watch face, the upper left corner button is the "ADJUST" button. Press and hold the ADJUST button for a couple of seconds. You should start to see something flash on the display. Some models will have many options to select in ADJUST mode. To scroll through them, press the MODE button, which is in the lower left corner. You set the hour, minute, seconds, month, date, and year each separately. When you are done, press the ADJUST button again and you'll be back to normal time keeping.
If you want to learn more about your G-Shock, there is something called a "MODULE" inside it that is the brains of the watch. You can find that on the back of the watch, outlined in a rectangle. Usually a 4 digit number. You can download the manual for your watch using that number, if you enter it on a CASIO website:
http://support.casio.com/en/manual/manuallist.php?cid=009
Dec 28, 2017 | Watches
How to adjust hands with anolog time
pull the adjuster knob out and wind it around to move the hands
push back in when the time set is right
Dec 26, 2015 | Casio GA110GB-1A Black G-Shock Digital...
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
ADJUSTING ANALOGUE CLOCK
Keep pressing 'select mode' button until you get to H-SET. Than hold 'adjust' button until screen starts to blink. Now you can adjust analog clock by pressing 'start/stop (search)' button. When you are finished, just press 'adjust' button once. That's all.
Feb 18, 2009 | Casio AQ163WG 1BV Casual Sports Watch with...
Instrutions for casio g600
A --- B Setting the digital time.
C __ D
Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Set time, Date, etc:
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
Good luck,
Techjoel
Jan 06, 2009 | Casio G-Shock G600-1AV Wrist Watch
Setting prolem
all you have to do to set the watch from 24h to 12h is press the adjust button-the seconds flash-now press the g button/light and that switches to 12h-then press the adjust button and it,s done.
May 22, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Setting analog time
go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Mar 13, 2007 | Casio AW80-1AV Wrist Watch
Casio G-Shock GW500A-1V Wrist Watch Logo
4,138 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
