Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Drum wont turn
The machine fills and empties but the drum wont fill can you help the machine is about 6 years old
  • 1 more comment
  • pompeymo Jun 16, 2008
    the drum does fill up but it will not turn
  • debmor2002 Jun 21, 2008
    I have a "candy sprint 1300" the drum won't turn or spin, its still going through the motions o.k. had the motor tested + the brushes are fine, now i'm thinking its the door lock or balance ?? I had this problem in the past + it started working again after a bang.
  • prem mathew May 11, 2010
    Is your exit hose connected behind at the correct height, that is about 3 feet high, & then into the standpipe?
    President:
  • 1,294 Answers
Take a look at the connections on the door lock, mains off. Or try some WD40 on the door mechanism, not on the door. And open/close the door a few times.
Posted on Mar 04, 2009
  • 57 Answers
I WOULD CHECK THE FLYWHEEL THAN LISTEN FOR SOUND OF THE MOTOR IF YOU HEAR IT SPINING THAN IT IS POSSIBLE THE SHAFT IS BROKEN OR SEIZE
Posted on Jul 15, 2008
My front loading machine does not appear to be pumping water in a light flashes H20 and beeps
? im confused are you saying its not filling with water or its not emptying of water , if its not emptying of water , yes its true the pump in it is driven by a motor and yes they d go bad and yes if the pump wont turn then yes it wont empty out , this makes sense to the blinking light of water detection you see ? ohh and most times the pump and motor are all one assembly , if it wont fill with water then you need to ck the inlet valves they get clogged or go bad too ) there is no motor that is assoc with these valves that I know of
May 25, 2016 | Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
The drum is not turning but the power light comes on hear a buzzing sound coming from inside also its still heating up
If this machine is older then 8 years, It may have died. Also, If the machine was recently over-filled with too many clothes, and if it is over-filled on a regular basis, it can destroy the machine's ability to turn the drum. We had a similar problem with an old machine...someone over filled it and the drum died.
Mar 28, 2011 | Washing Machines
DRUM MOTOR NOT WORKING TO TURN DRUM. PROGRAMMER OPERATING OK AND ALSO PUMP MOTOR. HOT AND COLD WATER FILLING MACHINE OK AND EMPTYING OK.IT WOULD SEEM TO BE THE MOTOR AT FAULT? THE MACHINE IS 6 YEARS...
Your question was head "microwave ovens" but I think you are talking about a washing machine.
Replacing the motor is a matter of judgement as to the reliability of the machine generally.
If this is the first time the machine has failed in 6 years, then I would have the motor replaced.
If there have been a series of faults, then replace then machine.
(Incidentally I assume that you checked the drive belt).
Jan 06, 2011 | Microwave Ovens
Wfl 2260 5 years old The drum does not turn the
if you can here the motor running have you checked the drive belt is still fitted to the drum,,,they fall off at times or wors still they brake,,,
Jul 04, 2010 | Bosch WFL 2063 Front Load Washer
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
Sep 25, 2009 | Hoover Washing Machines
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint washing machine
INSPECT THE BELT MAKTYBE BROKEN OR CAME OFF ??????????LET ME KNOW
Nov 29, 2008 | Samsung WF337AA Front Load Washer
Drum wont spin
Check brushes in motor, replace if worn
Oct 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Could be a motor problem, maybe the carbon brushes are worn down & need replacing
Nov 01, 2007 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
