Question about Kodak EasyShare Z915 Digital Camera
I have a z915 kodac easyshare camera and the lens is stuck out and it will no longer turn on, what do you think is the problem?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 09, 2010
Dropped my Kodak EasyShare Z915 digital camera - won't turn on..
It is toast - same thing happened to mine - the shock from the impact killed the LCD.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Cameras
Camera not operating with new batteries
John this is going to need looked at to determine the malfunction.
Jan 27, 2013 | Kodak EasyShare Z915 Digital Camera
Kodac EasyShare DX7590 Mainboard
Hello, Check Ebay Item #230915354361 This camera should have same components that you are looking for,Do Not know the cost to ship to Jamaica ?
Hope This Helps
Jul 14, 2012 | Kodak EasyShare DX7590 Digital Camera
Have inserted new batteries but Kodac easyshare C813 will not turn on - any suggestions?
The camera has errors due to failure of the main control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck giving wrong inputs to the control unit.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 23, 2011 | Kodak Easyshare C813 Digital Camera
I dropped my kodak z915 camera while taking a picture. Now the lens is stuck and it will turn on and turn off quickly. how do I fix it?
It appears you've knocked the camera lens barrel out of it's guides. On the outer rim of the lens barrel are small channels which match with metal pins sticking out of the barrel guide (the part of the camera where the lens slides into on switch off) I've seen people tell others on the Net to bash the camera with lens down on a hard surface. PLEASE, PLEASE don't do that. It may work once in a thousand tries but it will more than likely make the problem worse and even snap the metal pins off or scar the barrel for good.
I'm afraid it sounds like a definite trip to the repair shop. Its certainlý not something you should attempt yourself unless you feel confident you can handle extremely complicated and extremely fiddly work. I purchased probably 20 broken cameras to work on before even attempting opening a customers camera and of course they are all different. Your camera requirers a complete pulldown as the lens is the last item to be extracted. I pulled apart over 50 lenses and then got them reassembled before daring to do the same to a customers and fell confident about it. So your camera deserves a good tech who knows his stuff. I always worked under the rule "if it's not fixed you don't pay" but I doubt if there's too many around anymore. Maybe that's why I'm not dring a Ferrari.
Apr 10, 2010 | Kodak EasyShare Z915 Digital Camera
I don't have a good user manual for my new Kodac EasyShare M1063
This is the link for the manual. Enjoy
http://www.kodak.com/global/en/service/publications/urg00868toc.jhtml?pq-path=13052
Jul 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare Z915 Digital Camera Logo
778 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
