Question about Samsung SGH-A877 Impression Cell Phone
Sgh a877 say tap the centerof the target. repeat as the target moves.screen not responding at all . thanks. paris
5 Suggested Answers
SOURCE: i found message ' tap the centre of the target
Hello!
Dont worry about it , it's just the calibration wizard.Tap the centre of the target (the cross) with the touch pen (you'll have to do it more than once befor finishing the calibration)
Posted on Nov 04, 2009
SOURCE: I have a Samsung Impression SGH-A877. It's frozen - Black screen
Hi! Most probable the software is broken, so you need to go to a specialized service and get it resofted.
Posted on Dec 12, 2009
SOURCE: "no event" box on my screen, sgh-a877
Drag the box back to the widget bar.
Posted on Dec 29, 2009
SOURCE: Instructions to replace the samsung sgh-a877 lcd screen?
wath is a seril no. of need for speed hot pursuit 2
Posted on Apr 10, 2010
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
I did a hard reset now the phone is stuck on the target how do i get past it
To Hard Reset the Mobile,that means Unlock the Mobile from the Network Lock use the Unlock code,You can get the Correct Unlock code here
http://www.superunlockcodes.com/samsung-sgh-a877-impression/rs12wp9/ and Unlock it.....
Dec 06, 2010 | Samsung SGH-A877 Impression Cell Phone
Hello, I have a Samsung SGH A877 cellphone and for some reason the touch screen has stopped responding. Is there anything I can do to get the touch screen back to normal or should I order a new phone?
First try to take the battery out. When you put it back in it resets it. If that doesn't work do you have a warranty? My Blackberry went out and Verizon replaced it for free just as long as the glass is not cracked. Let me know what happens and I will try to help you out further.
Dec 04, 2010 | Samsung SGH-A877 Impression Cell Phone
The touchscreen on my Samsung Impression SGH-A877 does not work at all. Started about a week ago when I noticed that it was not selecting the things I touched on the screen, but selecting the entry above...
Hi,you will have to replace the flex of the phone.
The flex make the touch pad to function,also the functioning of the number keys.
When you replace the flex the touch pad and the key will function again.
Thanks for using fixya.
Oct 01, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung sgh-a877
Sounds like your phone has a digitizer if the touch screen is not responding.you can purchase a digitizer on ebay, they cost anywhere from $9-16 and if you are in the U.S you can send it to us to fix it for you for a reasonable price.
http://shop.ebay.com/i.html?_nkw=+Samsung+SGH-A877+digitizer&_sacat=0&_odkw=C113+unlock+code&_osacat=0&_trksid=p3286.c0.m270.l1313
Jun 10, 2010 | Samsung SGH-A877 Impression Cell Phone
I reset my main memory when it was done the restart automatically.there is given on the screen "tap the target firmly and accurately at each location on the screen.the target will continue to move until...
you have to update its firmware. it is corrupt. but first ,When Omnia powered off,hold onto the Call and Cancel buttons, press and hold the power button for a approximately 5 seconds until the reset screen shows up. If you do it wrongly, you will hear the samsung jingle and the startup animation.When it is on,hold onto the Call and Cancel buttons,poke the soft reset hole and the reset screen shall show up. otherwise, visit here for upgrade options.
regards
Mar 12, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
I found message ' tap the centre of the target repeat as the target moves ' in samsung d980 how can i solve this problem thanks
Hello!
Oct 21, 2009 | Samsung SGH-D980 Cell Phone
IQue 3600 won't respond properly to stylus. Responds if you touch one item down the lists. Example, to OK something, you have to touch right below the OK. It just recently started this, Maps display...
I solved the problem by re-calibrating the screen. Go to the home icon on the screenn tap preferences, date and time, then tap digitizer. Then follow the prompts and tap exactly on the target Xs.
Thanks!
Oct 01, 2009 | Garmin iQue 3600 GPS Receiver
My imate pdal is stuck on the align screen... as many times times as i tap on the target to align screen on all the four corner, it just comes back to the centre..... the whole process repeats but just...
use this Software...
codefactory.es/downloads/mobile_speak_pocket/release/MSP_RemoteAlignment.zip
add www. in the front...
dont 4get to rate me ...!!
Jan 23, 2009 | i-mate PDAL Pocket PC
Samsung SGH-A877 Impression Cell Phone Logo
182 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
