Question about EliteGroup GeForce 6100SM-M Motherboard
Cannot Install 2 GIG Memory Upgrade
Currently got a 512mb installed. Won't boot up with the 2 gig stick at all, Boots with the 512.
  • tennyson Jun 23, 2008
    The memory started working in the board inexplicably... I tried a 1gig stick in it, didnt work, tried the 2 gig again, worked, put back the 512, worked.. and it's been working since.
The motherboard is really.. not that nice to RAM, i had 2 GeIL 1024MB DDR2 800 modules in at one point, i cleaned inside the case, and next time at bootup i got the beep beep beep.. apparantly one of the ports does not like 1gb no more.. had to get my head around it..
Posted on Jul 04, 2008
I got the same problem and when I ask for help on the net, surprise! Lots of cases like ours... some MoBo accept 1G in each slot and others accept only one, in my case, it doesn´t accept even one in one slot. Memory is Kingston, the best one in my opinion, but it only works with 512. I´m taking my receipt and I´ll change for another model.
That´s my tip, change it while ECS doesn´t solve this problem!
Posted on Jul 01, 2008
The motherboard only supports 2gigs of memory. the other problem might be the 2gig stick itself since its probabaly damaged or broken if it came from a generic brand or was cheap priced. you should run memtest to see if it reads the 2gig stick
Posted on Jun 21, 2008
  • 385 Answers
This motherboard supports maximum 2 gig memory (please refer to this link). However, it has 2 memory slots where only 1 gig memory will hold in each slot.
Try putting in 2 - 1g memory module and see if that works.
Thanks,
Lolita
Posted on Jun 16, 2008
  • 156 Answers
You got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
Thanks for using Fixya.
Feb 07, 2011 | Averatec 3200 Notebook
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
Dear Sir, Have P4VXASD2+ with AMIINT - 10 BIOS (07.00T 02/4/01?)Release 09/05/2002. 512MB memory in 2 sockets. Try to replace with 2 of 512MB but computer part boots, closes down and re-boots etc. OK with...
does your motherboard support 1 gb memory? sometimes motherboards have limitation when comes to memory!!or try to check the modules if it is functioning!!
Jul 12, 2009 | EliteGroup P4VXASD2 Motherboard
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
P35-611 Memory upgrade question
hi try going in to your bios at the start when starting your pc up press f2 this should get you in to your main board settings finding the sys on your bios when you go into the bios it should come up with your cpu hard drive and mem installed if you need to reset this to 2 gig if you dont and its reading 2 gig then go to save exet yes to this and reboot your pc this may fix your problem .
this may just be a read problem and it needs to learn that you have a 2 gig mem
if not let me know and we can try another way for you ok
hope this helps ok
all the best
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
EliteGroup GeForce 6100SM-M Motherboard Logo
122 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
