Question about HP Pavilion dv6000z Notebook
During start up my hp pavilion notebook says error code 3? Black screen. When I press enter it says check media cable? Please help.
    Genius:
  • HP Expert
  • 1,325 Answers
Hello
here is a link that gives all aspects about this notebook..
http://h10025.www1.hp.com/ewfrf/wc/product?product=3224052&lc=en&cc=ca&dlc=en&lc=en&lang=en&cc=ca&submit=GO
this link, gives you some questions/ansers --
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_facet=%5esolveCategory$&tmp_qt=media+cable&product=3224052&tmp_product=HP+Pavilion+dv6000z+CTO+Notebook+PC&lc=en&dlc=en&cc=ca
media cabel refers to the DVD-CDROM -- have you made any changes lately to the hardware ? there must be a loose cable inside the notebook
may this serve you well :)
Posted on Nov 09, 2010
Black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 19, 2013 | HP Pavilion dv6000z Notebook
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    My hp pravillion dv6000 will not start up and go to windows. instead it makes radid fast beeps that will never end. not just 3 beeps, but over a hundred that never end untill you power it down with on off...
    That means it has massive hardware failure, could be bad memory, etc. The board is getting an error code before the memory or while the memory is trying to post.
    May 06, 2011 | HP Pavilion dv6000z Notebook
    ERROR:-1603 fatal error during
    1) Click Start > Run
    2) Type msiexec /unreg and press enter and wait until it appears to have
    finished.
    3) Go back to Start > Run
    4) Type msiexec /regserver and press enter.
    5) Try to install 'management' again.
    Jan 13, 2010 | HP Pavilion DV6700T Notebook PC
    Hp tx 1000 black screen please hel
    Power drain would be a better solution in this case.
    1.first shut down the comp
    2.unplug the charger
    3. remove the battery
    and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
    Nov 28, 2009 | HP Pavilion Tablet Notebook
    Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
    hi,
    if nothing(even hp logo ) is not coming on the display then please try this.
    1.remove the battery and then press the power button for 30 sec.Again refix it and check.
    2.If windows sound is there then this mught be the issue with display.
    3.If there is no windows sound might be the issue with RAM so please get it checked.
    May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
    My laptop won't boot up
    Firstly you should preform a HDD check. There should be a built in HDD check somewhere in the BIOS. Enter the BIOS by pressing F10 at the HP logo during boot.
    I would strongly recomend using another HDD checks if you are able to, as the built in one dont always find the errors. The one we use at work is MHDD(you can find it with a quick google search).
    If the HDD is OK you should try running a full system recovery. You can start the recovery process by pressing F11 at the HP logo during boot.
    If the HDD is defective or this doesnt solve the issue the unit will most need to be sendt in for service.
    Mar 05, 2009 | HP Pavilion dv9000z Notebook
    Hp pVILLION DV 1000
    This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
    The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
    1. Turn on or restart the computer.
    2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
    3. Use the right and left arrow keys to select the Advanced tab.
    4. Use the up and down arrow keys to select Boot Order .
    5. Follow the on-screen instructions to change the boot order.
    Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
    3. Press the F9 key to reset the BIOS to default settings.
    4. Press the F10 to save the changes and exit the BIOS settings menu.
    I think it will you to fix your problem.
    If still have problem then tell me more about it.
    Thanks
    Iqbal
    Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
    HP Pavilion dv6000z Notebook Logo
    71 people viewed this question
    Top HP Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
