Question about Frigidaire FRT18B4A Top Freezer Refrigerator
My Frigidaire FRT18SJW2 has a bad starter relay. I have the correct parts but need to know how to wire it. I'm looking at a red and a white wire.
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: start relay on my whirlpool fridge
hi thanks for the question the white wire goes to the pin on the left the red on the right black at top thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: starter relay wiring
Red wire goes into the L side.
Posted on Oct 09, 2008
02 merc stalled checked relays fuses dtr pcm starter and patwill not engage starter keys trans ok also no burnt wires checked all but ignition switch need help
If you want help you need to explain a little better . When you turn the key to start , the starter doesn't engage , correct ? On top of the instrument pane is there a little red light flashing when you try starting the vehicle ? Need to know model so I can look at wiring diagram .
Dec 19, 2016 | Cars & Trucks
Solenoid wiring diagram
If you have a relay to the starter solenoid then red one from the battery then red from the relay to the starter solenoid. The starter solenoid earth wire goes into the starter housing for the brushes if not then the red wire from the battery goes direct to the starter solenoid big terminal. The other big terminal will already got inside the housing. That takes care of the really heavy wires . The small wire goes to the little terminal between the big terminals.
Jul 27, 2014 | 2000 Ford Expedition
Free wiring diagram davidson
starter relay is 4 legs....so now the big red wire is from the battery, the big white/red spiral wire connect it to the starter motor,,,,the 2 small wires is live wire and ground....the ground is your switch....the other wire is your live wire,,,
Oct 15, 2013 | 2011 Hero Honda Glamour 125 PGMFI
2003 dodge caravan 2.4 motor will not start has full power going to starter but not when you turn ignition there is no power at small wire at starter
before i can go any further i have seen bad starter kill power to small wire, does not sound correct i know but it happens, remove the small wire from the starter and test it for power with key in the crank position.
if there is power at small wire when removed from starter then starter is bad. let me know the out come. good day
Oct 06, 2012 | 2003 Dodge Caravan
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
How do I get the red&white wires out of a Starter/overload assbly
it's very easy but alittle tricky. use something thin and hard. there's a small tab on those connecting clips that you must press down while pulling the wire out of the relay.if you have a replacement relay on hand, then go head and carefully crack open the relay in order to remove the wires.
MAKE SURE YOU UNPLUG UNIT B4 DOING THIS.
Jul 16, 2009 | Freezers
I don't understand my wiring diagram.How does the positive and negative cables hook up to the starter relay and to the battery.I have one small red wire coming from my wiring harness does this wire connect...
Hi and welcome to FixYa,
If the starter relay in your version uses blue / white and red / white wires, then to my understanding, connection would be:
  • blue / white - goes to the start switch and is supplied with +12 on starting;
  • red / white - goes to the starter circuit cut-out relay. This cut-out relay controls whether the starting relay gets a ground based on neutral/gear and clutch lever conditions.
Good luck and thank you for asking FixYa.
Jul 08, 2009 | 1985 Yamaha XJ 700 X Maxim
Starter relay wiring
Oct 01, 2008 | Frigidaire PLHS267ZA Side by Side...
Cant get starter relay wired properly dont know which wire goes where
Hey Mark,
Dark Green from ignition and Black/White go to relay coil.
Red from battery to relay common
Dark Green from starter solenoid to relay N.O.
Mike
Jul 31, 2008 | 1986 Jeep Comanche
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
