Question about Apple iPhone Smartphone
Repair a water damaged iphone - Apple iPhone Smartphone
    Novelist:
  • 141 Answers
You can send it off to apple repair centre and if the internal sensors arent triggered and your still within your warrenty they MAY fix it for you but cant promise anything, either that or pay the unfortunatly
Posted on Dec 29, 2010
  • 29 Answers
There is an app for that.
Posted on Nov 22, 2010
My iphone got water damaged, how do i repair it
Put it in a packet with rice and leave in the sun for a day.
Apr 13, 2014 | Apple iPhone 4S
Hi, I droped my iPhone 4 in water. The iPhone stopped responding. The touch function is no longer working. I would like to know if its possible to repair it and what is the estimate...
It all depends on the extent of the damage. The digitizer is just one thing to stop working. The rest of the phone might go soon, and water damage isn't covered under warranty.
I can get you a website link of parts, but you might just be better off buying another phone.
Here's the link:
http://cnn.cn/shop/apple-iphone-c-256_1059.html
Thanks
Aug 25, 2011 | Apple iPhone 3G
I have an impact 7000 can I get new battery The phone started cuttin out dropping calls ATT store said battery indicator showed some water damage Waiting for IPhone in Sept so would just like a quick...
unfortunately replacing the battery wont solve the problem.
the battery is where the external water damage indicator is but its actually the phone that would be damaged, and even worse, water damage is almost never repairable at a close to reasonable cost.
Your best bet would be to look up a used phone on a local classified website and get something to tide you over til the new iphone.
reference: 4 years of working for a canadian telephone company, 6 months of which working as a technician.
Jun 13, 2011 | Pantech P7000 Impact Crystal Hard Case
My iphone fell into water
If you check craigslist in your area you can usually find shops that offer water damage repairs. I have known many iPhones to be repaired from water damage fairly inexpensively.
Aug 19, 2010 | Apple iPhone Smartphone
Droped my i phone in water what do i do
Easy Steps to Follow for iPhone or iPhone 3GS Water Damage Below are 12 easy steps to follow if you're iPhone has experienced water damage. Read on below for more details on each step.
  1. Do not turn it on - that means, do not touch any buttons.
  2. Do not turn it on - that means again, do not touch any buttons!
  3. Do not turn it on - again, this will cause the phone to short circuit if there is ANY amount of water in it
  4. Take it out of the case and remove the sim card.
  5. Shake out any extra water.
  6. Use a blow dryer on low heat for about 15 minutes to try and blow air through it and get rid of some of the water. Make sure it is on low heat.
  7. Shake it out again.
  8. Put it in a bag of rice, make sure it is completely covered
  9. Leave it in the rice bag for 2 -3 days if your phone was in water for less then a few minutes and 6-7 days if your phone was in water for more than that.
    Each day, take it out of the rice and use the blow dryer on low heat again for an additional 15 minutes. Then, put it back in the bag of rice.
  10. After 2-3 days you can check to see if it is still wet by shaking it a little to see if any water comes out. Sometimes, water may not come out so if you want to be sure, leave it there for 4-5 days.
  11. After you've left it in the rice bag for enough time, then try and turn it on to see if it works.
Remember: This is not foolproof, but it has worked for many people. The whole point of putting it in rice is to help it dry and remove the moisture.
What to do if you just damaged your Apple iPhone or iPhone 3GS First, do not turn the phone back on. By instinct, I wanted to turn it on to see if it was working. However, if you do this, the phone will short circuit because you are putting electricity through it while there is still water in it. Water in an electronic device may not break the item. However, too many times, people turn on the item right after to check if it is still working. The act of turning it on causes you to put electricity through it. Before, when it was off, no electricity was running through it. By putting electricity through something that has water in it, you will cause the item to short circuit.
I repeat this a couple of times just so everyone understands. If you can dry out the item and remove the water, it just might work. The water will eventually cause the electronics inside to rust, but it may not cause the item not to work.
So, after not turning on the item, what do you do? You try to dry it out. You let it sit. Some people recommend putting the iPhone in rice. Take a large amount of rice, put it in a gallon ziploc bag, and then stick your iPhone in the middle of it. You don't have to wrap it or anything, the rice won't damage it. See the video below for an example of how you do this. Basically, the rice will help to **** the moisture out. If you try this method, change the rice each day. Another method is to apply some form of heat against the phone - whether it is your blow dryer or a small room heater. You want to run low heat air through it for 30 min. to an hour every couple of hours. This will help dry out the moisture. Your entire goal is to help remove the moisture. Until you know the moisture is completely gone, do not turn it on. Depending on the amount of water, some people have recommended waiting anywhere from 2 to 7 days.
Finally, after doing all of that, slowly turn on your phone. Surprisingly, for many people, these methods of waiting and drying out the phone completely worked. Many people online had accidentally dropped their phone in the pool, tub, sink or some other source of water. For us, none of this work since the phone had been washed and sat in water for more than 30 minutes. However, if you drop your iphone into water for only a few seconds or a minute, then, a lot of times, drying it out will cause it to work again.
Apple store policy and procedures for water damaged iPhones or iPhone 3GS water damage One other tip. If it doesn't work, or it doesn't work right, you can now get it replaced for $199 at the Apple store. Previously, they wouldn't replace it since water damage automatically voids the warranty. Yes, the 2 year or 1 year warranty you have is not safe if you get water damage. There are 4 sensors on your phone (picture examples are below) - 2 that you can't get to while opening, and the other 2 that you can see. The first one is in the small round hole on top left of the phone (the earpiece hole), and the other one is in the bottom middle that separates the connector. If you shine a light and look at either of these, the sensor will be pink if water has touched this area. Because of this pink sensor, the folks at the Apple store will not honor your warranty which is what happened to me and my boyfriend.
But, the good news for us all is that Apple has now changed its policy. If you have a water damaged iPhone (pink sensors!), Apple will now allow you to replace it for a refurbished phone for a lower cost. It's $199 for a refurbished phone and the warranty is only 90 days, but this is a huge difference between the full price of $599 or $699 contract free phone that we had to pay to replace the water damaged phone. Also, don't forget, if you've bought your phone from Best Buy or used a credit card that offers protection, you may be able to get some of your money back or get the phone replaced for free. Don't miss out on these options since you will have to pay to replace the water damaged phone.
Repair OptionIf your sensors are pink and your iPhone is not working even after you've tried to dry it using the steps above, then you may want to consider sending it to a repair shop. Millieamp is a service that can potentially repair your damaged iPhone. For a small fee, they will first start out by evaluating the damage. Then, they will let you know how much they think it will be to repair. At that point it is up to you to decide if you want them to repair the phone or if you want to buy a new one. It is worth having them take a look in case they are able to repair the phone and you don't have to buy a completely new one, especially if you just bought the phone. Check out their iPhone and iPod repair services. They just might help you save a bundle.
Regards
Iversh
Jun 26, 2010 | Apple iPhone 3G
IPhone Smartphone: i dropped my apple 3g iphone in water after 2 hrs ...
Do a search for water damage iphone repair on craigslist in your area. There are usually several people with local shops that can fix this for you.
May 17, 2010 | Apple iPhone Smartphone
I have a water damaged 3g 8gb motherboard with a pin broken off the LCD connector on it, can this be replaced and where do I get this fixed?
We repair water damaged iphones but if a pin is fused to the board chances are it is too far gone.
Feb 02, 2010 | Apple iPhone 3G
Iphone home button not working due to water damage
If you are familiar with repairing electronincs I would recommend opening the unit up and inspecting the internal components of the home button and the corresponding logic board connecting point for corrosion.
You can get a new home button for about $6 on eBay. Just eBay search for iPhone Home Button.
Hope this helps, Please Rate Me!
Jul 09, 2009 | Apple iPhone 3G
Iphone water damage
I tried everything to get my iphone to work after a small incident with a toilet bowl. I used rice, silica packs, blow dryer, towels in the sun, etc. My brother-in-law told me about the ifixyouri website he used for his broken screen. I called them up and they walked me through the website and I over night fedex shipped it to them. I really wanted my iphone to work again, because like an idiot I never backed it up in iTunes. Well, I just received it back in the mail and................IT WORKS!!!!!! So, I am recommending them to everyone. I am soooooo happy. Good luck!!!! The site is www.ifixyouri.com
Sep 10, 2008 | Cell Phones
Apple iPhone Smartphone Logo
80 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
