Question about Acer AL1916B 19" LCD Monitor
My Acer AL1917W LCD monitor will not stay on. I keep turning the power button on and off. When I turn it on, the monitor works for a few seconds and can see what is on the screen, then it disappears. I keep turning the power on and off, but the monitor won't stay on for more than a second or two. I have tried unplugging and re-plugging all cables, but that didn't help. Any ideas??
SOURCE: al1917w lcd monitor resolution problem
Get a new video card, you dont need the best video card to support 1440*900. It is affordable and the best solution.
Posted on Sep 10, 2007
vikkisuri
  • 46 Answers
SOURCE: monitor stays on for a few seconds then goes out
This problem is very often caused by dry electrolytic capacitors on the inverter board. If you have some skill with soldering you could try to change them. When buying new ones ask for LOW-ESR capacitors for switching mode power supplies (SMPS) and 105°C, they are a little bit more expensive than normal electrolytic capacitors, but are designed for this aplications so they lasts more. Normal el. caps will also works fine so when you cannot buy LOW-ESR for SMPS use normal ones.
This is a FIX ONLY for Rosewill R710E 17 inch Flat Panel LCD Monitor!
Symptoms: The LCD screes shows up for half second or more and turns black, but the LED light remains green and reflecting the light to the screen can be seen the screen working.
Changing the 1000uF condensator at 16V should make work your back lights like new. Usually when this problem occur you will see malformed (has to be flat at the top) at the top that peace of bad condensator. The board on work for this issue is the inverter located at the left side looking from the back. NOTE*** To prevent any accidental damage of other boards unscrew the inverter and work independently with it, specially the part with the soldering.
had same problem with my Sceptre X9S-Naga II 19", which I'd had to replace within a week of original purchase because of an apparently-identical problem at that time. Pissed me off that this second monitor had just 2 years' worth of use on it...I paid $500 in the day, now worth about $200 if new. I wonder if this lack of longevity is to be expected from LCDs, esp. considering the CRT I finally offed was 9 years old with never a problem.
In the end, it breaks out like this:
470uF/35VDC electrolytic capacitor from Radio Shack: $1.66
Hours here and there over the course of a week spent dissassembling, poking, prodding, and googling: incalculable
Satisfaction of resurrecting monitor: $200 plus landfill karma-credit
I had some assistance from a very public-spirited electronics repair website put up by a guy in Malaysia, without which I probably would have run the thing over with a truck by now. His pertinent web page is http://www.electronicrepairguide.com/lcd...
There is a /lot/ of info there--sift through the maze of pages and see what he's got to share from his tech experience.
Details: In my case, I had no fancy meter to check almost anything while in place, just an aging DVM. There was a chance that one of the lamps was bad (an easy but possbily expensive replacement) so I decided to pull them out of the pockets they slide into (like...fission control rods at your nearby nuke plant) so that I could directly see what they were doing during the brief power-on time. These are amazing ultramini fluorescent tubes, or at least closely resemble them in color, proportions, and wiring. They're powered by an inverter circuit that feeds them chopped high-voltage, I believe. When I reconnected them, now out of their wells, and powered up, they ALL came just partway on--not the full length of each tube, much like a fluorescent tube does when it is struggling to start--and just before my power-indicator would quit. I swapped around the lamp connectors to see if the performance would change, and it remained the same...so I knew it wasn't likely to be any lamp that was the problem.
The power supply was producing SOMETHING at some points on the board, but I had no idea what to expect or where. 80VDC at one point seemed wildly high, but turned out to be OK in the end.
On about day 67, brute force triumphed over lack of training and service data: I found the guilty cap by desoldering four of the 14 electrolytic caps on the board. I chose the caps I did to start with only because they were 'paired,' so I knew I'd be able to do crude side-by-side comparisons of resistance on them, in order to maybe-kinda-check if one was totally shorted or likely out of spec. The first pair checked out as approximately matching each other. The next pair...DIDN'T. It was ONLY then that I noticed that the cap with the substantially lower resistance (but not a full short) was, actually, BULGING a bit, as I'd hoped to notice from the outset, but it was very subtle. The bulge in the top was less pronounced than at the bottom, so it would never have jumped out at me without having desoldered them, so as to reveal them top and bottom.
A trip to Radio Shack netted me the $1.66 replacement. By this time, I was quite used to plugging and unplugging the AC power cord from the guts that were sprawled across my table, and I had laid out the board on a piece of insulating newspaper with the "cold-cathode" lamps splayed out haphazardly around it. During all testing, on powering up, the power light would come on in a blinking mode, apparently indicating the problem status. I'd hit the button to see if by chance it was going to stay lit solid for more than a few seconds, but every time it would resume the blinking status after a few seconds.
But now maybe it would be different...at last. Beads of perspiration built up on my forehead as I completed the resoldering of the caps I'd pulled. I restored the minimal external connections to the power-board and hit the power button...and was sorely dissapointed to see that it did ALMOST what it had done before. Now it looked like the lamps lit fully--but still would quit after the same brief duration. WTF? How much MORE time could I possibly spend on this?!
It's impossible to make this a long-story-short at this point, but believe it or not, I'm editing a bit of the pain here. The next day, after several more hours of messing with it and hating that the dissassembled stuff had polluted my kitchen table to the point where I was forced to eat elsewhere, I decided I could at least put parts of it back together, even if I WOULD end up running it over with a truck or throwing it out on the freeway. Also, I wanted to see how the lamps looked now, during their brief "on" duration, but when back in place, shining through the actual screen. So I powered it up again after this partial reassembly, and saw...nothing. It was getting WORSE? Where was the lamp-light?
I began to reassess my technique. What connectors had I maybe been too willing to assume didn't matter for testing this power-supply? I reconnected the chassis-ground wire. No difference. WAIT A MINUTE. I had dislodged a wide, fine connector from the back of the screen when I had been taking the lamps out a few days prior. But that shouldn't matter--I'm not sending the thing any data. Still, I'll reconnect it since I have to anyway. The excitement built, but no, STILL no difference. So this was getting weirder--why no lamps NOW? OK, just to be thorough, I reinstalled the video connector cable, to my laptop as before, though I had not needed this during the testing of the lamps while they were out of their ports...so why should it matter now?
Well, it did, though I can't say why. The bright white lamp light, I was thrilled to notice, was peeking through two small holes in the back of the frame, and...it WASN'T GOING OUT this time! So...the $1.66 cap really HAD cured the whole problem; the rest of the issues were artificial problems caused by my ignorance in testing and reassembly laziness.
Back to the basic bad-cap failure: I have NO idea what percentage of similar symptoms would be explained by this silly cap failure, but if I have this happen again, the first thing I will do is gat a bright light and a magnifying glass to inspect the caps for bulging. Even seeing nothing, I think I would remove the caps methodically, and either half-ass test them (as I did with less-than-optimal equipment) or simply replace them all. I'd guesstimate that you could buy all caps for about $20...though it would be a painful thing to do this and still not have a working monitor, I admit.
Posted on Nov 22, 2007
  • 556 Answers
SOURCE: AL1917W Drivers
Try Here
http://support.acer-euro.com/drivers/monitor/al1917w.html
Posted on Dec 22, 2007
Matampong
  • 153 Answers
SOURCE: Acer LCD (AL1917W)
After removing the back cover screws that you saw, ok, there is a screw under the stand holder. Remove the cover that covers the stand holder joints. you can remove it using a flat head screw driver, it is removeable only it appeares stuck to the back cover. After you unscrew, use flat head screw driver and carefully by pushing to the side of the LCD bend. Carefull you might break the cover. Good Luck.
Posted on Nov 25, 2008
SOURCE: AL1917W LCD Monitor
Appears to have been a virus, a variant on the win32 issue. What is troubling is that it was only caught by NOD32 on system startup. However the problem is solved.
Posted on Apr 15, 2009
Lcd acer al1917w dispay problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Repair Kit ACER AL1917W ILPI 031 LCD Monitor Capacitors Not the Entire...
Apr 05, 2014 | Acer Ferrari Computers & Internet
Acer AL1917W LCD monitor powers up but no image at all.
The CPU and PSU, have absolutely nothing to do with a monitor.
HERMAN has the correct response. For the info you posted.
When you have a video problem, you post what the motherboard is or what model PC, the graphics card, and what drivers you have installed.
Aug 07, 2012 | Acer AL1917W LCD Monitor
Monitor black screen
To me this sounds like whats called "bad caps" problem. The capacitors in the PSU have gone out of tolerance and the back light is switching off. If this is the case you will need a workshop repair or if you know how to solder you could replace the capacitors in the PSU for the back light.
Jan 24, 2018 | Acer AL1917W LCD Monitor
The green power light comes on, but the monitor comes on for a few seconds then it goes out. when i press the power off and then back on, the monitor comes on for a few seconds and then cuts off each time...
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 03, 2010 | Acer AL1917W LCD Monitor
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Monitor won't stay on. each time I turn it on it comes up for about 3 seconds and then goes black
aburnsrn, Cold-cathode-fluorescent-lamps don't light-up, you will be looking at black screen!! If unit older than 5-6 years trade for new wide-screen. Else read for about 2 hrs. in my fixya profile for more options.
12fixlouie
Feb 27, 2010 | Acer AL1917W LCD Monitor
I have an Acer AL1917W. My computer screen keeps on going black screen and say no signal. HELP!
Make sure your cable is secure, check driver, or you could have a video card thats not working properly
Dec 31, 2009 | Acer AL1917W LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Acer AL1916B 19" LCD Monitor Logo
413 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
