Question about GE Washing Machines
When my washer model#wpse4270aww is in WASHING mode it really knocks and it's NOT off kilter, i know what that sounds like. But this is different, the tub is very loose even when there is nothing in it and the machine is off. we don't have a repair contract on it anymore and wanted to know if it's an easy fix for us-like just a tightening thing or would it cost alot to have a repair on it-or should we just look a buying a new machine, it is almost 10 years old., we bought it in March 2001
  • 822 Answers
If drums lose...........sounds like bearing is knackered....
after 10 years you done well
might be easier to buy new machine
cheers
Posted on May 28, 2017
  • 18 Answers
SOURCE: Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Posted on Feb 04, 2007
SOURCE: washing machine - knocking sound at end of cycles
actually by the sounds of it, you have a top loader. simply apply a small portion of grease to the brake drum and this will take the severity off when stopping. if you dont do this incidently, eventually your coupling will break.
Posted on Jul 15, 2008
  • 78 Answers
SOURCE: Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Posted on Jan 14, 2009
bozcro
  • 867 Answers
SOURCE: Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Posted on Jul 14, 2009
  • 6277 Answers
SOURCE: Is my washing machine too
Although you say it's level I would recommend you try my method to make absolutely certain before considering spending money!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 16, 2011
Why does whirlpool washer wtw6200vwd twist pant leg and sleves!
It's an inherent problem with this washer due to the designed movement of the agitator. My wife had the same problem. We solved this and the multitude of other problems we had with this washer by going to home depot and buying the cheapest washer they had. Told the rep we wanted a washer with no computer, no special cleaning agitation designs, etc. He said "you want this one". we bought it, they delivered it and we now have cleaner clothes and no twisted sleeves, pant legs, error messages. When they were ready to leave they ask my wife if she wanted to keep the old washer or wanted them to haul it away. Her response was "I never want to see that thing again."
May 29, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Sep 15, 2009 | GE WJSR2070B Top Load Washer
Need to disassemble Whirlpool Ultimate Care II washer
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
Click on the model that matches your machine.
The new window will give an assembly diagram of your machine. Clink on the diagrams on the left-hand side for different assemblies.
Mar 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Drum is really loose and when hits spin cycle makes loud noise
Most front loaders are pretty much the same and it sounds like your tub bearings are going bad. There is also a problem in some front loaders where the drum arms corrode and break. You won't know until you pull it apart. If you are doing the work yourself it depends on the parts you need. You can knock out old bearings and match some up.
If you are paying someone, it may be cheaper to buy a new washer..
Jan 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
what shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to tomagic3@yahoo.com
thanks
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
