Question about Aiptek DV8800 Digital Camera
Recorfing tv this product says that it can be hooked up to my tv or dvd player and record movies and tv. but so far it hasent worked. I have tried using all the cables it came with but i might not be dint something right. PLEASE HELP.
  • 4 more comments
  • Ace Spades
    Ace Spades Jun 16, 2008
    i have the cable with the white and yellow and usb on one end and the usb/tv out on the other, and i have the cable with red white and yellow on one sideand the av on the other
  • Ace Spades
    could you explain a little it more what a rca connection is?
  • Ace Spades
    it does have rca. and usb, ut i have another cale with rca but no usb. the first on econnects to the female part in my camera called the "usb/tv out". and the second one hooks up to the one called "av in"
  • Ace Spades
    thank you so much
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does your camera have any rca connections or just a usb plug?
  • Tim Babcock
    Thats pretty slick. What kind of cables do you have?
  • 2,794 Answers
Sure.
The yellow and white wires you have are called RCA connectors. There aka media cables too. You should have male ends that can connect to the output of your TV by matching the colors.
I just need to need to know what kind of connects you have on you camera to record the TV signals with.
Posted on Jun 16, 2008
  • Tim Babcock
    Tim Babcock Jun 16, 2008
    To record movies to your player. You have to have 2 RCA outputs in the back of your tv. If you have a VCR or a DVD recorder, you can use the output jacks out of those. The yellow cord will plug into the video. The white cord will plug into the audio. Sounds like the player doesn't record in stereo unless you have a red one as well. If so plug that into the other audio jack in the back of the tv.
    Use the AV in on your camera to plug the rest of the connection in. Tune your tv into what you want to record and set your camera for record.
I have Magnavox DVD player/vcr DV225MG9, does it record from vhs onto dvds? And if not, what do I need to get so that I can copy all of these old vhs movies to dvds?
it won't record dvd's its only a dvd player. only the vcr records
if the vhs movies your trying to record are movies like star wars and stuff like that it's copy protected and no worth the trouble. if it's home movies or something you recorded from tv they might work. if you get a dvd recorder/vhs player.
Jul 20, 2015 | Magnavox Televison & Video
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
Oct 28, 2008 | Zenith XBR411 DVD Recorder/VCR
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
Dvd compatibility
use nero 7 8 to make your movies best easyest
Jan 22, 2008 | Microsoft Windows XP Home Edition
CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Dubbing vhs to dvd
If you try and record a video with copygaurd it will only record a tiny section. If you press stop or return for 3 seconds you will cancel the recording, try pressing the pause button you edit out adverts, i have not tried this yet but it might work.
Dec 31, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Apr 22, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Aiptek DV8800 Digital Camera Logo
114 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
