Question about Karcher 2500 PSI Pressure Washer
I want the complete wheel start cord - Karcher 2500 PSI Pressure Washer
  • 7,733 Answers
Starter cord will not rewin
hi
your spring has stretched
inside your starter assembly where your pull cord winds round
inside you have a spring that is now bent the chinese call it a washer
either take it out and straighten it in a vice
or you will have to buy a complete wheel that you wind your pull cord round
regards
neil
Nov 24, 2012 | Ryobi Garden
Pull cord is tangled
Unusual, but it does happen. Probably should replace cord. Obtain new cord, can be found at almost any hardware store, then remove top engine cover (cowl), usually held on by 4 bolts,two in front and two in back.If your mower has a plastic cover on top of cowl, remove it first. Remove old cord by holding wheel (looks kind of like a pulley) so that it does not spin freely once old cord is cut. Cut cord anywhere outside of the housing as close to the housing as possible. Carefully release the wheel so that it can unwind. You will see where the old cord is tied to the wheel. use needle nose pliers and grab hold of the knot and pull old cord out. Now for the fun part. You need to "rewind" the spring by turning the wheel clockwise while looking at the inside of the housing. Once you have turned the wheel to a point where you might break the spring, back off one turn to be sure you have not over wound the spring. Usually, about 5 or 6 turns of the wheel clockwise is enough, use your own judgment. The tighter you can get the spring, the better the recoil will be when you let loose the cord when starting engine. You need to line up the hole in the wheel to the hole in the cowl as close as possible. Use a screwdriver or some other small sturdy object to "lock" wheel in place for next step. There is plenty of openings through the cowl in which you can lock the wheel to keep it stationary while attaching the new cord and to keep the holes lined up as close a possible. It can be difficult to "fish" the new cord from the outside of the housing and into the holes through which you need to pull the new cord through. I have found that if you take a flame to melt the end of the cord so that it will not unravel makes it easier and if you can bear the heat, while the cord is soft from the heat, twist cord in a spiral shape. This will make "fishing" much easier.Once accomplished, tie a knot as close to the end of the cord as possible and pull line back towards the outside with a little strength to "seat" the knot. Remove screwdriver and let the tension of the spring rewind the new cord into the housing. If the spring completely unwinds then pull on the cord from the outside so the wheel turns at a minimum of on turn so there is always tension on the new cord. Route the new cord through the eye on the mower handle then install pull knob. Pull excess line through pull knob, tie knot, then cut off excess cord. Should be ready to go.
Aug 25, 2012 | Mtd 22" Yard Machine Push Mower
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
Replacing cord on polaris 250 ATV ??
CORD? THE ONE TO START THE ENGINE.
Park the Polaris ATV on level ground in an area with plenty of light. Allow the engine to cool if it is warm so that you don't burn yourself.Remove the four Phillips head screws from the corners of the metal cover that the cord is coming out of using the screwdriver. Pull the metal cover off the engine. Unwrap the cord from around the turn wheel completely.Spin the turn wheel using your hand until the nut securing the cord is at the top of the wheel facing you. Grab the metal stem on the cord with the pliers. Loosen and remove the nut using the box wrench. Hold the stem to keep the cord from turning as you loosen the nut.Pull the cord off the turn wheel and through the hole on the metal cover. Keep the nut just in case the new cord did not come with one. Insert the metal stem on the new cord into the hole on the metal cover. Insert the stem into the hole on the turn wheel.Tighten the nut onto the stem the opposite way than you removed it. Spin the turn wheel counterclockwise until you hear the spring lock into place. Wrap the new cord around the turn wheel. Make sure that the cord does not overlap itself. Replace the metal cover to the engine. Replace and tighten the screws to secure the cover to your Polaris's engine.
  • Dec 04, 2011 | Garden
    I need a replacement power cord for the 3 wheel Revo scooter. Where can I get one?
    The AC power cord is a standard cord used on computers and a number of other electronic devices. They can be purchased at any Radio Shack for about $9. If you have the old cord, bring it with you to match up for the new one. If you don't have the old one, draw a picture of the cord receptacle and bring it to the store. I describe the wall side as a three prong grounded plug and the Revo side of the cord or charger side as a trapezoid shape receptacle. See the link to Radio Shack for the complete picture:
    http://www.radioshack.com/product/index.jsp?productId=3875423
    Hope this helps.
    Mar 19, 2011 | Pride Mobility Products Victory 9 Scooter...
    Will not start
    completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
    Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
    Pull cord getting stuck
    Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
    Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
    Electrolux EL5020A VacuumCleaner - taking apart
    these[ things] you talk about are called lock clips.with a little force and a small screwdriver they open be careful not to snap them, take your time as you move along; the lock clips will start to reveal themselves more openly again take your time ,after the casing is opened it should reveal the electrical cord.;before you start this procedure make sure the electrical cord is unpluged from the power supply hope this helps you.adrian
    Feb 16, 2009 | Electrolux EL5020 Vacuum
    Samsung HLP5063W Tv
    while replacing the color wheel you know you see two cords running from it the blue/white cord and that copper cord. if you replaced both the color wheel and lamp, then it could be that copper cord just switch it around i did that and now my tv works
    Jul 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
    Electrolux Oxygen 3
    Most cord reels have a stop on it, it is a rubber wheel and when dust gets on the wheel, they won't always stop the reel. It would have to be opend up to get to the cord reel, then you could clean it out.
    Jan 12, 2008 | Electrolux Z5935 Bagged Canister Vacuum
    Karcher 2500 PSI Pressure Washer Logo
    Top Karcher Garden Experts
    John Trevino
    andy just round the...
    Level 1 Expert
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
