Question about Kenmore Dryers
Modle 417.80042990 Ser # XD02113080 about every minute or so it will make a thump noise.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 09, 2010
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
I HAVE A GE GAS DRYER MODEL DDG5980VALWH SER. 3F302890G. WHEN THE DRUM TURNS IT MAKE A THUMPING SOUND,,NOT REAL LOUD. MORE OF A THUMP THEN A SQUEAK.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | GE Dryers
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
heatman101
Dec 07, 2010 | Kenmore 64882 Electric Dryer
IRobot 560 Roomba making thumping/light clicking noise.
under warranty take it in for warranty repair or exchange
you try to fix it and the warranty is voided
just tip it upside down and check for threads wrapped around brushes and rollers / wheels
Nov 22, 2017 | iRobot Roomba 4210 Bagless Robotic Vacuum
Thumping noise while running
sounds like the bearings are bad or something is catch in the fan
Apr 03, 2009 | GE Zoneline AZ55H09D Air Conditioner
Thumping noise when apply brakes 1990 Accord
yes my cv axles had to be replace cause of the same thing but when you replace one side you need to do the other side at the same time cause when 1 goes bad the other is not that far behind . i know from experience
Nov 18, 2008 | 1990 Honda Accord
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
