Question about Haier HPAC99ER Air Conditioner
My AC not working
Hello, My AC unit is working. T-stat is working when i turn the fan on. Its just the unit outside I could see the fan is not spining. What do I need to do?
  • 1 more comment
  • Trishee Jun 16, 2008
    Thank you for getting back to me so quickly. Yes that is correct, the fan inside is letting out air but no cool air. Because the fan in the AC unit outside is not spinning.
  • kent158 Jun 22, 2008
    I have the same problem. The AC compressor will run and put out cool air for a few minutes. The fan that blows the air outside does not look like it is working. I have the back cover off but I can't find a way to get the front cover off to see the outside fan nit.
  • Richard Perkins
    Richard Perkins May 11, 2010
    Hi there!
    Just to clarify-
    The fan inside works on/off, but you are not getting any cooling effect at all. The outside fan is not turning at all.
    Is this correct?
    Genius:
  • 1,036 Answers
Hi again,
The electrical supply needs checking in the outside unit.
Start at any supply fuses, and work around to the compressor.
If it is getting a supply out there, then it is a control issue. There should be a thermostat or controller that will turn the outside unit on if cooling is required. This is the defective part, as the signal to start is not getting there.
Check the outputs from the thermostat on the inside - one contact should close to turn the outside unit on.
Hope this helps. If it enables you to fix it please take a moment to rate this as fixya!
If not, I'll go on further
Thanks.
Posted on Jun 16, 2008
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
AC unit comes on, but fan doesn't work. It works with furnace.
check for loose wiring to Tstat, or the new stat has failed.
if the stat has a fan on switch and when on the fan works then replace the stat
Apr 10, 2013 | Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Fan not working on my CPLE36-1C AC unit outside. Why?
Hello Tim First Turn the power off! Try to turn the fan blade with a twig or something.Is it tight ? It should turn freely.If yes open the cover where the wires connect & check if the capisitor is expanded or leaking if so replace that with the SAME one (uf value&volts).Check for burnt wires also.The capicitor is a round or oval shaped can (looks like a large battery) with wires cliped/pluged in on top.Next let the motor cool off 1 hour and restore power.Does it BUZZ for a short time then stop?If yes its new motor time.Good luck
Jul 07, 2010 | Heating & Cooling
Unit turns on but furnace won't come on. AC works,
see if your t-stat is calling for heat take a jumper wire from terminal r to w on the board if the heat comes on replace the t-stat
Feb 05, 2010 | Heating & Cooling
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Fan will come on for heat(auto), but not for AC or set to ON
You have a blower relay in the furnace that's probably bad. In the heat mode the blower is on a temperature relay, in cooling mode the blower has to come on immediately so there is another relay for cooling. The green wire on the thermostat feeds that relay, so if you go to the furnace and shut the power off and find the green wire from the thermostat that feeds that relay and replace it, being careful to mark all the wires before removing them, also the relay terminals have numbers for identification.
Apr 07, 2009 | Heating & Cooling
MY AIR CONDITION ONLY PUT OUT WARM AIR EVERYTHING SEEMS TO BE OK FILTER TURNS ON OK BUT THE OUTSIDE UNIT HUMS BUT DOES NOT FAN
Sounds like a bad start run capacitor. The exhaust fan motor may be bad too. Be careful, this unit delivers 220volts of electricity.
Jun 17, 2008 | Goodman Heating & Cooling
Haier HPAC99ER Air Conditioner Logo
234 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
