Question about Dryers
Dryer start making noise: bad bearing or pulley. what to do?
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 11, 2010
It just started to make a squeaking sound. Like metal rubbing on metal.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 07, 2015 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Aug 26, 2014 | Frigidaire Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
I have a GE dryer that started making really load screatching noises. I took it apart and replaced the motor and the belt. It ran for a few minutes and started making the same noise. I am not sure what...
The idler pulley bearing might be the trouble. If the dryer has an idler pulley that tensions the belt, check this bearing in the idler pulley. If it is a bush type, just oiling it might be all that is required. Also make sure there isnt any piece of wire etc in the drum bearing. You might have to take the drum out to check this. However the most likely cause of a SCREACHING noise is the idler.
Mar 13, 2011 | Dryers
My dryer makes a scweeking noise as it spins
check the motor bearing maybe it needs some lubrication.
Aug 06, 2009 | Dryers
Me GE elec. dryer is screeching, how do I solve this problem
First, stop using the dryer. It is telling you "I'm broken".
Several things can cause the noise you are describing:
1. Belt is slipping. Lost proper amount of tension on the tension pulley as spring has become weak.
2. Rear drum bearing has rubbed completely through and the drum is now riding on the metal support, This can cut into the drum support and trash it.
3. Tension pulley has got bearings that have gone dry (bad). Fix is to replace pulley.
4. Chance that the bearings in the motor itself have gone dry (Bad). Some you can oil and some are sealed. In either case, if they are making this noise, they are probably no good and motor needs replacing.
Good Luck and let me know how it turns out.
May 11, 2009 | Amana DLE330RAW Electric Dryer
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Dryer noise
What is the make and model number?
Premmy
Oct 14, 2008 | Frigidaire Dryers
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Open Questions:
Dryers Logo
Top Dryers Experts
