Question about Mitsubishi WS-55809 55" Rear Projection Television
1080 tv comes on for about 3 seconds and goes off
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
When it goes off do the self check--on front of set press and hold both the Menu and input (device) buttons for at least 5 seconds and release both buttons.
The power light will blink a two digit error code, most common is 2 blinks, 2 blinks, a pause and it will repeat it several times
Let me know error code and I will tell you what it means and how to proceed.
Regards, SD TECH
Posted on Nov 09, 2010
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
Blurry picture in top quarter of screen
this is caused by the panel's edge contacts coming loose(delaminating). would have to replace panel(approx. 1500.00 usd.)
Mar 01, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
Older medallion 55" 1080...switched itself
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
My mitsubishi hdtv1080 is stuck on camcorde, how can I get it off?
When I turn the Mit. 1080 on, the green indicator light comes on for about 3-5 seconds then it goes off. TV never comes on (no picture or soun, nothing). What is the problem. thanks
Feb 06, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I was trying to connect my hdmi cable from my ps3 to our tv with hdmi capability, but when i chose video input 1080, the screen went black and i cant see the menu in my ps3 anymore, pls help me on how i...
make sure you turn the tv to hdmi before turning on the ps3 because the ps3 will sense the hdmi cable and a message will pop up asking if u would like to switch to hdmi and the message goes away after 30 seconds so click yes and it will come up 2 more times click yes both times and then it should be good hope this helped
May 13, 2009 | Sony Playstation 3 (PS3) Console
Mitsubishi WS-55909 dm board repair
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
meeh.shell@yahoo.com
Oct 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
