Question about Toshiba 27A34 27" TV
Model 32HF73 I replaced the remote from Toshiba and I don't have a vcr or anything hooked up to it and the remote won't work. Sometimes when I was pressing the on/off switch a bunch of times,not turning the tv on, then the remote would work but just for awhile. So is it the sensor?
    Scholar:
  • 100 Answers
Hello, usually if the remot control is ok, then the infrared receptor need to be replaced, he is placed near the stand by light.
in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility
that something is wrong at the microprocessor circuit.
i hope it was helpful!! Let me know if you need further guidance
Posted on Feb 25, 2011
My Toshiba TV remote clashes with my blaupunkt soundbar,is there anything I can do.
Hi David.
If you mean the Blaupunkt Soundbar also responds to the Toshiba remote signal, the only work-around I can suggest is to partially mask the soundbar, perhaps with a matt-black spray-painted short tube.
I had the same problem with a TV and VCR of equivalent brands.
After attaching a slightly angled 1 inch long black tube-mask with contact glue on edges, the problem stopped. I seldom use the VCR so if I need to use it I stretch my left arm to let VCR's remote talk to VCR only. Funny thing is, VCR remote doesn't affect TV...
Nov 27, 2017 | Toshiba Televison & Video
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
No remote - toshiba vhs w522
Unfortunately, many models are now without menu buttons. You will probably want to go to the Toshiba website and request a replacement remote, or try to find a remote that will work with all toshiba models.I don't recommend a universal one, only because they can sometimes be junk, if they are intended to control many different kinds of devices. You may want to try a single-device universal remote instead.
Mar 16, 2009 | Toshiba W522 VHS VCR
Universal remote control codes for toshiba t.v. amd syphonic vcr
have a jensen universal remote need codes for toshiba tv vcr combo lost book.
Jan 19, 2009 | Directed 434MHZ Remote Control
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Is this TV High Definition
Your Toshiba 32HF73 is a high definition TV. So good ahead and get the HD cable box and enjoy the picture on the HD channels! Please give feedback if I answered your question, thanks.
Jan 16, 2008 | Toshiba 32HF73 32" TV
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
Toshiba 27A34 27" TV Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
