Question about Canon imageRUNNER 2220i Grayscale Copier
I have a Canon IR 2220i, we had service on it and some setting was changed. I am not paying the vendor to come out and change the setting back. Prior to service when we scanned to it documents were saved as one continuous document, after service they are now single pages. how can I find the setting to change it back?
SOURCE:
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Posted on Jan 26, 2008
spinal
  • 287 Answers
SOURCE: IR 2220i - change clock
Hello Debant2,
I believe on this model you go to additional functions (an asterisk looking button just to the left of the nine key pad) and this should give you a menu screen which will include a tab on the left that says timer settings. Press it and you should see where you can change the time. Take care. :-) .......SPINAL......
Posted on Apr 19, 2008
SOURCE: scanning from Canon MP530 to Mac Powerbook
If you;ve installed the MP Navigator software from the CD, then you should be able to press the scan button on the printer with your Mac connected and the MP navigator will open automatically on your Mac ready to scan. You can also try going into Preview (the Mac app) and from the file menu select Import... and it should open a scan window.  Hope this helps!
Posted on May 07, 2008
  • 67 Answers
SOURCE: Unable to scan from MS Office Tools - Document Scanning
you have to update the firmware
Posted on Jul 25, 2008
What is the meaning of error code e 355 canon ir copier
http://www.copytechnet.com/forums/canon/21924-error-code-355-350-canon-ir-2220i.html
Apr 07, 2016 | Canon Office Equipment & Supplies
First i changed the fuse gear canon ir 6800 and put the fuse unit back to machine . when i turn it on the machine show the error 000005-000010 what can i do ?
hi . that error indicate that the cleaner roll ( in the fixing unit )is over . maybe there is a sensor disconnected or misplaced. check That section and clear error from service mode
copier / function / clear / err ok.
Feb 27, 2016 | Canon Office Equipment & Supplies
Why code 000190
You have to empty the waste toner box and clean it
Jul 21, 2014 | Canon IR-2220i Copier RECONDITIONED
How do I log onto imagerunner 2220i?
if connected then web browser and copier IP address
Apr 05, 2010 | Canon imageRUNNER 2220i Grayscale Copier
How to change the port number of canon imagerunner 3570 for scan n email
On the control panel select additional functions- system settings- network settings, then scroll down for e-mail settings. The port can be changed there. You can also type the IP address of the copier in internet explorer, and change it though that interface.
Jul 15, 2009 | Canon imageRUNNER 2220i Grayscale Copier
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Imagerunner 2220i - Scan-to-email Configuration
http to the machine and its under general settings can't think of exactly where off the top of my head
Nov 03, 2008 | Canon imageRUNNER 2220i Grayscale Copier
Hello Debant2,
Apr 01, 2008 | Canon ImageRunner 2220I Copier
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon imageRUNNER 2220i Grayscale Copier Logo
47 people viewed this question
Clive
Clive
old marine
old marine
