Question about Xantrex Technology RS400 Sine Wave Inverter
I have a xantrex rs400 inverter, the remote switch is discontinued. Is there a way to use a different switch?
4 Suggested Answers
  • 4 Answers
SOURCE: my Xantrex rs400 stop working
First and foremost, It's a piece of ****!
I've been fighting with Xantrex for 3 years now and after 3 replacements I'm still stuck with the same erratic behavior. I don't trust it and Xantrex is not even responding anymore.
This is my review at Amazon
http://www.amazon.com/XS400-400w-Sine-Wave-Inverter/dp/B000A7MW5E/ref=sr_1_1?ie=UTF8&s=sporting-goods&qid=1256963563&sr=8-1
I know this is not helping you much but I thought it would be nice to know that you are not alone!
Richard
Posted on Feb 14, 2010
nitrospawn
  • 290 Answers
SOURCE: Grundfos Pump On Xantrex Modified Sine Inverter?
if the power of you pump is above that of the inverter you intend to buy it will not work, buy one with at least 200watt difference.NB these pumps might take lots of power so your batteries might run down quickly
Posted on Apr 22, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I got an error of ER 05. What does that mean?
Hi and welcome to FixYa, I am Kelly.
E05: Flashing Fault LED: Flashing Alarm: Beeping = Output on inverter is shortcircuit
- Disconnect your output terminals and see if you still have the code. This is telling you there is an external short.
- If you still have the error with the output terminals disconnected start looking for internal inverter shorts to the output connector. (Chaffed wire / hot wire signs / internal + lead ground)
- If you have Circuit Breakers / fuses on your output side open all the CB/s or remove all fuses then turn on the CB's / install fuses one at a time until you note the Er05 error. Then troubleshoot the shorted circuit with an Ohm Meter.
Thanks for choosing FixYa,
Kelly
Posted on Mar 19, 2011
N manual to cover and remote
PDF]Owner's Manual Freedom Basic Remote Xantrex Freedom ...
www.xantrex.com/.../Freedom%20Basic%20Remote/Freedom%20Remot...
Freedom Inverter/Charger Remote Control Panel is not intended for use in .... n. Freedom charging. INVERT. O ff Invert function Off. Power Up Indications and Default V ... Xantrex covers both parts and labor necessary to repair the product, and ...
Product Information: Roamio Remote Control - TiVo
https://support.tivo.com/articles/Product.../Roamio-Remote-Control
TiVoAllow Pairing mode: This pairing mode is for manually adding a new remote control or transferring a remote control from one DVR to another. When you put the ...
[PDF]REMOTE CONTROL RC-N - Bernafon
Jan 01, 2016 | Televison & Video
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
Overcharging batteries on freedom 20 inverter charger
Go to the Xantrex website and run through the support section. Then look up the closest service center.
Aug 15, 2009 | Xantrex Technology Heart Freedom 20 12...
My Xantrex rs400 stop working
Richard
Aug 05, 2009 | Xantrex Technology RS400 Sine Wave...
Intermittent operation. Appears thermostat
No solution so far. But wanted to tell you that I'm having the same problem. I went through a lot of time, money and effort without success. Xantrex has abandoned me not responding to my e-mails anymore.
There could be a problem with the way it is (or not) grounded. I'm still experimenting.
I'm using a cheap $39.00 westmarine as a replacement. A bit noisy but so far much more reliable!
Richard
Jul 24, 2009 | Xantrex Technology RS400 Sine Wave...
Inverter will not shut down. I turn off the remote switch in my motorhome or the master switch or the switch on the inverter and it remains on. This will discharge my batteries won't it?
depends on the serial # of your inverter.... the inverter switch on the machine should be turned off and controlled by your remote. If the switch is on at the machine, the remote won't control that part of it.
Jul 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Is true sine wave better than modified sine wave.
I'm not sure what the application is but I will offer the following. As a retired electronics engineer i can say for sure that a true sine wave does not have any harmonics in it. A modified sine wave will have some harmonics and other what I would call " trash content" depending on how it is modified.
Loringh
Nov 16, 2008 | Xantrex Technology RS400 Sine Wave...
Xantrex Technology RS400 Sine Wave Inverter Logo
56 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
