Question about American Standard Home
When i flush the toliet the flapper stays up and will not fall back down so toliet keeps trying to fill
  • 6,674 Answers
Make sure chain or rubber lift device isn't holding it up, or it isn't rubbing against side of tube beside it. A new flapper can be purchased at most hardware stores, and are easy to replace, if it comes down to that. Did this just happen suddenly, or was something adjusted or changed in the tank?
Posted on Nov 09, 2010
  • 37 Answers
Adjust the chain that connects the flap to the handle give it some slack but not so much as to get chain laying under the flap good luck and hope it helps
Toilet does not have good flush
The power of the flush has nothing to do with the fill valve. It has to do with the flapper. When the flapper is opened, the surge of water into the bowl is what causes the toilet to flush. If the flapper closes too quickly, it will take away from the powerful flush. Try to find the correct flapper for that type of toilet and stay away from the "universal" flappers.
Feb 06, 2014 | Home
After flushing the toliet continues to run. flapper will not automatically go down
Replace it and see if fixes it. The flapper is designed so that it stays afloat until all the water empties from the tank, then gravity takes over and closes the hole up and thus fills up. If you have a ballcock then the flapper may get trapped underneath when you flush it.
Feb 27, 2013 | Home
I have a Jacuzzi low flow toliet. Sometimes the water won't shut off after it is flushed
A frequent cause of this is a defective flapper. If the flapper does not seat properly after a flush, the refill water will flow continuously
Feb 19, 2013 | Home
My toliet keeps running. Have checked valves flap etc. I turned the water off , using the little toliet tap. Can I turn it on too much,making the pressure to high??
Replace the flapper. That is cheap to do. You can turn the water on near wide open And it should be ok. In other words, if you can't turn it on wide open, then something is wrong. I would just turn it on about 3/4.make sure your flat is not allowing the water to go over the top of the open tube.in the tank.
Jan 23, 2013 | Caroma 270W-RF Reflection Round Front...
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
After the installment when you flush the water will flush four(4) times in the bowl while the tank water is raiseing to the float level. Is this normal.
Most people have trouble with the flapper falling too fast and they get one with a float on it or one that drains water on the counterweight to keep it up long enough. It sounds like yours stays open too long. Get a flapper that will fall fast without any gimmicks on it. the shorter the chain is to the flush handle the better too.
Aug 21, 2011 | Fluidmaster INC #B1F09 9" Faucet Connector
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
I have an older toliet that flushes but not well. It flushes but does not get a strong whirlpool and ''flush through''. Sometimes after it is flushed it will have paper of some other small suprise still...
Soap or other buildup in the gooseneck of the drain portion. Try raising the water lvl in the back of the tank and add a float to the chain attached to the flap.
Sep 22, 2009 | American Standard Home
Tank will not refill after you flush
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Nov 16, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Home Logo
454 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
