Question about YouTube Computers & Internet
How do i becombe a member of you tube - YouTube Computers & Internet
    Guru:
  • 2,178 Answers
Go to the YouTube website and register - it's free.
Posted on Nov 09, 2010
Looking for second VIN# on 03GSXR 600 supposed to be on sticker somewhere on bike
The VIN may be found:
Under the seat stamped into the top of the frame LH side
On the front of the frame viewed above the front wheel
On the front right frame down tube
Under the seat on the rear cross member
Stamped into the steering headstock viewed by turning the handlebars to the left
VIN data build plates can be found:
On the headstock near the VIN
On the front frame down tubes
On the frame side tubes
Under the seat
The VIN plates are either riveted to the frame or on later models are in a black tamper proof sticker format
Nov 01, 2017 | Motorcycles
CAN,YOU REPLACE PICTURE TUBE IN A G3222 TV
NO, WE CAN'T. Fixya is a Q/A forum, we, members, all we can help other members is answering questions
You can try to find the part doing a google search using terms
PARTS, BRAND of your CRT TV, PICTURE TUBE
View these videos how a CRT tube is replaced:
Replacing CRTs And Repairing RCA CTC28 Color Television
Checking...
SimHelp Advice on CRT Tube Replacement
http://www.repairfaq.org/samnew/tvfaq/tvptrep.htm
http://www.barco.com/tde/%280251960790820610%29/TDE13/00/Barco_TechnicalManual_TDE13_00__Retro-Data-808S-picture-tube-replacement.pdf
Now, just a guess: presuming you will find that CRT tube, maybe the job of buying and replacig the CRT tube of your TV might cost you more then a new flat panel TV? I don't know..
Sep 12, 2015 | Televison & Video
Transmission dipstick tube won't go back in on this 91 Silverado. Just had trans rebuilt and everything in place except the dipstick tube.... won't go in at all.... any suggestions?
Remove the cross member, remove the torque converter bolts and back the bell housing bolts out about an inch, so the transmission will drop some. It's still difficult to get in, but it will go.
Apr 25, 2015 | Chevrolet Silverado Cars & Trucks
Becoming a member
to become a member in you tube you have to have one google account. you can create it for free
https://accounts.google.com/SignUp?service=mail&continue=https%3A%2F%2Fmail.google.com%2Fmail%2F&hl=en
Oct 23, 2013 | YouTube Computers & Internet
I like to watch indian songs you tube
Sir/Mam
Please provide the model or the brand name that you want to watch youtube. We (FixYa) member(s) can't help you in this way because we don't whether your cell-phone is supported to use internet or not?
So please mention the model or type that you are using.
Thanks for using FixYa!
Oct 05, 2012 | Cell Phones
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My peavey valveking vk 112 is making a whistling noise I changed the 2 main tubes and it is still doing it what coud be the problem and how can i fix it
A high frequency feedback can be very hard to isolate without test equipment... you MIGHT have a "microphonic" tube that picks up from the speaker and feeds back... Tap the small tubes with a pencil and see if any of them "ring"... gentle taps of course... If one seems sensitive, swap like numbered ones around to see if you can find a happy place for them. Electrically there could be a bad ground inside causing these.
I notice you have 4 tubes in the output... REMEMBER when you used matched pairs... the members of the pairs do NOT go side by side all the way down the string...
Put each tube of a matched pair at the ends of the string of four, and the other pair as the middle two...
Feb 12, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
When I upload video and save what next so I can see on youtube what next?
YouTube allows to upload media either motion pictures or videos on the network. Once uploaded implies the videos are pasted on the network spaces displayable at several levels. First, the pasted videos are at an area that is browse able during every YouTube visit. Depending on the extensive request to the YouTube user, media is shared with contacts on the network that require member ship on to explore the multimedia experience. YouTube member ships create the spaces to achieve social communications where several mentionable either text, picture graphic or multimedia communications are achievable. Each member of YouTube establishes an area of spaces where media is displayable. Once becoming a member of YouTube, ascertaining to acquire contacts with similar interest makes the media experiences extensively pleasant. The YouTube experience includes browsing through several media of interest to participating in social networking. Once acquired pleasant material on the tube, features like voting rates makes possible approving the media types that are displayable. The YouTube experience includes acquiring contacts that find interesting common communications issues. Explore though the YouTube site to discover the feature to members.
Feb 02, 2011 | Computers & Internet
Dented telescope tube
HOW bad? If they are small they will not affect anything. Contact your local astronomy club and have one of the members look at your telescope.
May 16, 2010 | Zhumell Dobsonian 10 in. (600 x 254mm)...
Open Questions:
Computers & Internet Logo
23 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
