Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
Posted on Dec 05, 2010
  • Vall
    Vall Dec 18, 2013
    It's depend on the type faucet:nee to open set screws or turn counter direction first handle till unscrewed,after take apart-its going simple if you have visual schematic or isometric sketch of replacement parts.
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How to fix delta shower single knob faucet
    Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
    Apr 29, 2015 | Delta & Single Handle Shower Faucet
    Installed a new KWC Domo faucet and its leaking (alot) under the sink
    Does if have a sprayer and is it still hooked up?
    Aug 14, 2014 | Plumbing
    New kwc domo leaking under (alot) sink
    mixing chamber of the faucet may be cracked
    Sticking of KWC Suprimo faucet
    My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
    Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
    I just replaced the cartridge in my KWC faucet and now it's very hard to raise and lower the on off handle. Any advice?
    It is possible that you installed a bad valve cartridge, it would not be the first one. It is also possible to over tighten the cartridge retaining nut, rare, but it can happen. In either situation you need to call KWC and ask them to send you a new cartridge asap. They are usually very easy to work with. If you need further assistance please let us know.
    Sep 16, 2010 | Grohe Plumbing
    Sticking of KWC DOMO model faucet.
    Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
    Thank you, Stuart
    May 11, 2010 | Delta Model 470: Signature Kitchen...
    I would definitely take it apart to find out what is causing it to bind, that is not normal. Make sure that you turn your water supply lines off under the sink, via angle/strait stops. From under the faucet there is one or two nuts fastening the faucet to the counter, they are usually screwed on just a little more than hand tight. The problem may not be fixable, so be prepared to replace the faucet.
    Mar 19, 2010 | Delta Model 470: Signature Kitchen...
    KWC Domo faucet sprayer won't switch between spray and stream
    Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
    TL
    Mar 17, 2010 | Plumbing
    Need instruction for installation pull out faucet
    firs you have to remove the handle
    remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
    take a flashlight and determine if you need an allen head screw or phillps
    remove the screw( be sure to cover your drains so nos small parts get in bottom
    remove the handle
    depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
    whatever remove anything holding the cartridge down (some require a cartridege remover)
    remove, take to store match up new and replace
    by all means turn water of under sinnk good luck
    TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
    Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
    Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
    1,839 people viewed this question
    Top Danze Plumbing Experts
    David Wiebe
    Level 1 Expert
    Donni Steen
    john h
    Are you a Danze Plumbing Expert? Answer questions, earn points and help others
